Trunion Bearings?
Discussion in '80-Series Tech' started by Scamper, Jun 12, 2003.
  1. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Hey B-
    I'm in the getting ready stages to do my birfs in about a month and have been busy downloading all the instructions and tips I find. I put together a list of the parts needed for each of the category A, B, or C rebuilds from your post the other day (on the birfs topic) so I could see it all in one simple grid. I then started going thru the instructions that Jim (and others) put together and posted in the Tech section, and I'm seeing these trunion bearings for your B rebuild kit, however, nowhere in Jim's instructions does it say anything about how these are installed or what you have to do to replace them.
    I've seen elsewhere where you've said this is an easy job, but looking at the BGB, it looks like you need an arbor press to get the races in/out. Or am I just reading too much into this?
    Are there any tips/instructions for this part of the job? With 91K on my truck now, if I do the birfs, I'd just as soon replace these bearings too if it doesn't make an 8 hour 1 :banana: job into a 16 hour and 6 :banana: job. Not to mention the :beer:.
    TIA,
    Tom
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Tom,
    I'll but in here. The Wulf is at a meeting of some sort at the moment.
    90366-20003 x 4. Drive the races out with a drift, install the new races, pack the new bearings with molly and go. You don't need to spend time cleaning up the old ones, just toss 'em over your shoulder. As you are not spending any time on clean-up and inspection the over-all time is not that much longer when you replace them.
    Dan.  :beer:
    BTW, 2 of mine were bad at 96,000 miles
  3. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Thanks Dan. Sounds like only 1/2 :banana:
    Tom
  4. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    Dan,
    Bad? The bearings or the races?
  5. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Bearings, both lower ones. A few of the rollers had flat spots. It felt "notchy" when the knuckle was turned back and forth(bare, with the tie rods removed).
  6. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Tom,
    Somehow C-Dan said in 3 lines what would take me 3 paragraphs.
    He musta left something out but for the life of me I can't figure out what was omitted.
    Oh well.... 1/2 :banana: for sure.
    -B-
  7. shocker
    shocker
    1,185
    1
    Apr 10, 2003
    Kansas City, MO
  8. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    scamper
    see if you can score a race driver set before you start, teh drift is great for removal but the race driver will save you a lot of cursing as you go on.
    I agree about a 1/2 :banana:
    Dave :beer:
