truck moves while in gear...??? help!???!
Discussion in '95-older Toyota Truck Tech' started by alteredraptor, Sep 7, 2011.
  1. alteredraptor
    alteredraptor
    306
    Media:
    8
    May 13, 2009
    southeast wisconsin
    alright... my runner which is a 5sp, developed a new trick in the time since my last post since i havent been able to fix the leak... now I have tested this a few times while on flat level ground. while in gear, and the clutch ALL the way pushed in, my truck will start rolling on it's own... can this be from a oil covered clutch or do I have another problem at hand?
  2. bryan89
    bryan89
    786
    Jul 13, 2010
    Charleston, SC
    i assume you are indicating that with the truck running, it still moves forward when in gear even if the clutch is depressed? which under normal conditions should stop the truck from moving.
    you said it was on flat level ground, but have double checked that its not just rolling forward by chalking the front wheels and jacking up the rear end and performing the same test? or is it moving fast enough to tell its not rolling?
    the only thing that could cause that is that the clutch is not disengaging completely. so your slave cylinder may be shot, leaking, or have air in the line somewhere. to me, oil all over your clutch disc would make it NOT move. so i would start with the slave cylinder.
  3. toyminator
    toyminator
    918
    4
    May 4, 2007
    St. Louis, MO USA
    There is some adjustment in the pedal that you can make too.
  4. KLF
    KLF Frame waxer SILVER Star
    6,182
    411
    Apr 5, 2003
    Southern NH
    Your truck is trying to tell you that it wants a new clutch.
  5. jynx
    jynx Turd Herder SILVER Star
    5,323
    1,039
    Apr 24, 2010
    Eagleville, TN
    Yes and yes.
    Based on your other post, I think you know that a new clutch is in your future, but adjusting the clutch is what will stop the engagement. Look under the dash just above the clutch pedal and up in behind the dash you will find the pedal adjustment screws. I had the same problem with a new clutch about a year ago, just have to adjust the pedal out so the clutch will disengage.
  6. alteredraptor
    alteredraptor
    306
    Media:
    8
    May 13, 2009
    southeast wisconsin
    ok, thanks everyone, it was the pedal adjustment, that's all good now
