transmission??
Discussion in '40- & 55-Series Tech' started by scruffydawg, May 28, 2003.
  1. scruffydawg
    scruffydawg
    16
    Jan 19, 2003
    I have fluid mixing between the transmisssion and transfer case on my fj-62. Is there a seal between the two and is it a bitch to change? Does it need to be changed asap? Thanks
  2. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    if its a manual, then there should be an equaliser hose that you can get that connects the two at the fillers. And it doesn't really matter that the two mix because the levels will remain generally correct. But if its an auto, and the fluids are different types, then you may need to look at getting it replaced. And if thats anything like the manual, you may as well recondition the whole lot while your doing it, cause you have to pull the lot out.
    Sam
    '79bj40
  3. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    All 62's in the US were auto's. Yep, there's a seal between them, gotta split the transfer apart and pull it off to replace it...
  4. Lost_crusiers
    Lost_crusiers
    46
    Oct 15, 2002
    The seal is fairly easy to change but there is a lot of labor($$$$$) if some one else does it. While everything is apart do a recondition/rebuild. I do not think you will save money by just fixing the one problem, the other seals bearings etc. will pop up just because Murphy makes them. :( :(
