Transmission won't shift when the trucks running but will when its not..wtf?
Discussion in '95-older Toyota Truck Tech' started by fjman, Jul 10, 2009.
  1. fjman
    fjman
    1,182
    16
    Jul 12, 2005
    DC
    So why would a 1995 4runner with a 5 spd suddenly have shifting problems? Never had clutch slippage or any transmission issues. Basically, it'll row through the gears with or without pressing in the clutch if the truck is NOT running. If it is running, you need to start it in gear and plan on leaving it there! Can't shift if the engines running, including reverse...
    So anyone have an idea what the issue is?
  2. raydouble
    raydouble
    1,523
    Media:
    13
    1
    Feb 11, 2008
    Rochester, WA
    Sounds like your clutch isn't releasing from the engine, do you have any brake fluid in your clutch MC?
  3. fjman
    fjman
    1,182
    16
    Jul 12, 2005
    DC
    Yeah, the master cylinder is full....
  4. raydouble
    raydouble
    1,523
    Media:
    13
    1
    Feb 11, 2008
    Rochester, WA
    I'd say that air entered the clutch hydraulic system or the MC/slave are toast.
    No resistance to shifting gears when the engine is off.
  5. KLF
    KLF Frame waxer SILVER Star
    6,300
    521
    Apr 5, 2003
    Southern NH
    Just because the clutch isn't slipping, it doesn't mean it's not worn out.
    Check the release hydraulics out carefully. If everything is working properly and there's no leaks, start collecting parts for a clutch job.
  6. fjman
    fjman
    1,182
    16
    Jul 12, 2005
    DC
    If it was the MC/slave cylinder, wouldn't i need to pump the clutch just to get resistance? If I start it in 2nd gear for instance, I can drive it around in second gear as normal, just can't shift out of second.... Even stop and go, clutch seems to work
  7. Jukelemon
    Jukelemon
    2,395
    2
    Dec 29, 2003
    Louisville, KY
    I agree with the clutch.
    I dont see how you can say the clutch works. What gives you the idea that it is engaging/disengaging if it not doing its main function when running?
    Sounds like the clutch is constantly disengaged i.e. would explain why you can shift when it is not running but it will not shift out when running.
  8. Tools R Us
    Tools R Us
    20,301
    1,606
    Jul 20, 2004
    Chandler, AZ
    Sounds like the clutch pilot bearing is seized?
  9. corax
    corax
    297
    Feb 12, 2009
    Eugene, OR
    clutch pilot bearing or clutch disc . . . I had the same exact thing happen about 8 years ago in my '88 p/u, found out the clutch disc springs broke and wedged between the flywheel and disc (keeping it spinning at all times)
  10. 2ndGenToyotaFan
    2ndGenToyotaFan Ice-Bound Moderator
    9,211
    45
    Jan 8, 2006
    It's complicated....
    Put the trans in 1st, push in the pedal, and start the truck. If the truck takes off, then clearly the clutch is not disengaging, or the pilot bearing is done.... Check out the hydraulic system, but if it checks out fine, you're gonna have to pull the trans one way or another.
  11. Bogo
    Bogo FOOF
    1,979
    187
    Feb 15, 2008
    On the farm
    I say warn bearing, synchronizer or shift key.
    Has it ever been low on oil?
  12. fjman
    fjman
    1,182
    16
    Jul 12, 2005
    DC
    well it looks like the tranny needs to come out.. never done it so looks like i may need to bring it somewhere :(
  13. missouriman
    missouriman
    751
    25
    Jan 28, 2007
    rapid city South Dakota
    is the release fork on the side of the transmission moving?
    if you are trying to check it alone, tie it back with a small ratchet strap and see if the clutch is still stuck.
  14. fjman
    fjman
    1,182
    16
    Jul 12, 2005
    DC
    is that the part with the rubber boot on it?
  15. PGH854runner
    PGH854runner
    700
    Sep 15, 2008
    Pittsburgh,PA
    i had this problem on an 86 civic it turned out thepreesure plate was cracked allowing partial disengagment but you couldnt shift it while running.......after a quick shift fork check you gootta drop the tranny
  16. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,019
    Media:
    17
    264
    Oct 1, 2003
    MN
    How did you get to this conclusion?
  17. 2ndGenToyotaFan
    9,211
    45
    Jan 8, 2006
    Dropping the trans is not that hard, just takes some patience. I replaced my clutch by myself in 5 hours with the help of a trans jack.
    It's not much more than turning bolts.... :cheers:
  18. digital
    digital
    196
    Oct 15, 2007
    ^^^^ What he said...Call one of your buddies over for the day and share a case of your favorite suds with him afterward.
    Having two floor jacks makes it easier when dropping the tranny. Disconnect the drive shafts, remove the shifter boots, tranny wiring harnesses and the bolts for the rear tranny mount and thats pretty much it.
    Go to your local auto-zoo and rent a bearing puller for free to remove the pilot bearing.
  19. missouriman
    missouriman
    751
    25
    Jan 28, 2007
    yes, go's in the pass side of the bell housing
