transmission went bad
Discussion in '40- & 55-Series Tech' started by pablo, Jun 4, 2003.
  1. pablo
    pablo
    83
    3
    Mar 5, 2002
    I just started hearing some bad noises in my 73 40 3 speed. Stock motor, transfer sua. Only first and second are making noise, possibly reverse but have not heard anything yet. I need advice. Really poor these days. How much longer than my 3 speed is an SM465? How much for a 420/ 465 swap w/o driveshaft mods (if possible)? I was planning on machinig a 3/4" spacer up front on the transfer case if I use a 420. Also thinking about a toyota drivetrain swap for a 4 speed if I can find parts for cheap. What do you guys have laying in your garage? Most interested in the adapter kit costs. Also concerned about the larger GM clutch friction disc not fitting well with the toyota flywheel and pressure plate..
    Thanks
    Pablo
  2. bsilva132
    bsilva132
    1,008
    Media:
    5
    5
    Jan 14, 2003
    Elk Grove, Ca
    I will have a 4spd bell housing/4sp trany/4spd t-case at the end of next week hopefully. Trany shifts smooth and the t-case was rebuild last year. Let me know if interested. I am just outside Sacramento.
    -Brian
  3. pablo
    pablo
    83
    3
    Mar 5, 2002
    Brian,
    What year of transmission, 74? &nbsp:Domestic? What month? Clutch?
  4. bsilva132
    bsilva132
    1,008
    Media:
    5
    5
    Jan 14, 2003
    Elk Grove, Ca
    I am guessing 74, but I am not sure. domestic. no clue on month, possibly 6/74 (production date of my 40). I know the engine was not the original so I am not sure on the drivetrain. I am keeping the flywheel and pressureplate for my SM420/3spr conversion, but the clutch disk will be sold. It was new (OEM) last year and I do not drive the 40 often. I also have a spare 4spd tranny and tcase. I am not sure of the condition of the tranny as it has been sitting around for a while and the tcase has a crack, but the internals are good. If you are interested let me know soon, as I am going to be unreachable after next week for 3 weeks (vacation).
  5. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    price-wise, the 420 is the 2nd-cheapest swap, with IIRC no driveshaft changes needed, but only a minor driveability improvement.
    The 465 requires driveshaft changes and the adapters are more $$.
    The FJ40 4-speed swap is a good one, but you'll need the driveshafts too.
    IMO, 3-speed tranny's are boat anchors and you should be able to find one for $25 plus freight or less....I've tossed all mine away as useless, sick of kicking them around...
  6. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    My 3 speed tranny clutch is nearing its final days. That will be the excuse that I need to swap over to an SM420. For the money and the end result (low first gear) it's definately worth the swap. Just my 2 pennies... :G
  7. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    That sucks the 465 adapter should be cheaper.If everyone used the 465 the prices may come down for when I do mine It would be a lot cheaper. :G
    Pablo I have 2 of the 3speed trannys laying on the garage floor.they were spares for my cruiser so I asume they work
  8. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    This is somewhat relevant-
    Are the parts available to rebuild a 420? I've been going back and forth between Toy 4 spd and 420 for months. My 3rd gear synchro ring is wearing so its about time. I guess I should call some tranny shops nearby and see if they would rebuild? Should I just call it a SM420 and say it was in 1/2 to 1 ton GM trucks from '47-'67?
  9. theo
    theo
    1,432
    Feb 19, 2002
    I talked to Inland Truck here in Missoula about the sm420. 3 variations depending on year and application. There are subtle differences in the synchros and possibly countershafts, input shafts, and main shafts. Also, they used it in up to 2 1/2 ton trucks, so you'll need to know more specifically what it came out of. He said the interest from off-roaders is mainly what's keeping the parts available. You know, enough people ask and they dig deeper to find what we need. Beyond that, "I know nuthingg"
    I do have a 420 that I'll rebuild some day. Maybe I should start sooner than later!
    ps - I rebuilt my 465 last year and had no problems with parts if that helps. 6.55 instead of 7.05 granny is only about 7% higher. Oops, wait, 5" adaptor, probable driveline changes and/or engine relocation. Not nearly as easy then as switching to a 420. My bad. :-[
  10. bsilva132
    bsilva132
    1,008
    Media:
    5
    5
    Jan 14, 2003
    Elk Grove, Ca
    for sm420 rebuild check out PinHeads website:
    http://members.cox.net/cglabe1/SM420/sm420.html
    It is pretty easy to do yourself. I swapped out the main shaft for my sm420 adaptor (old AA style) and I didn't have a manual and had never taken a tranny apart before. Just lay the parts out in the order you removed them. You can basically get new seals, gaskets, bearings, and 3rd and 4th syncros. The web site has all the info.
  11. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Any special tools? I don't have any gear/bearing puller type specialty tools. I guess if I get off my now lazy summer a$$ and find one, I could go ahead and rebuild while I drive the 3 spd into the ground. I remember someone saying the 420 is 1" longer then the Toy 3 spd? If so then my rear shaft should be fine, since its pretty extended right now after the lift, but I may be 2wd only until I get the front extended some?
    So what should I ask for when trying to find one? Just ask what the oldest chevy truck in the lot is and if it has a 4 spd? And then go from there?
  12. theo
    theo
    1,432
    Feb 19, 2002
    Reverse on the 420 is left and back. Reverse on the 465 is right and back. Easy. Should be 420 in '67 and older.
  13. bsilva132
    bsilva132
    1,008
    Media:
    5
    5
    Jan 14, 2003
    Elk Grove, Ca
    Read Pinheads write up. It explains which 420's are better and what vehicles to look for. The later ones don't have an oil slinger so you don't spill the tranny fluid out the front onto the clutch when pointing down a steep grade. When I pulled mine apart I did not have a bearing puller. I just used a chisel and a hammer and just tapped around the bearings until it came off or went on. Takes a while but still works. Pinhead goes over what is needed and the basic process.
  14. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I re-read Pinhead's writeup but didn't see anything about how to find the better sm420? ???
  15. bsilva132
    bsilva132
    1,008
    Media:
    5
    5
    Jan 14, 2003
    Elk Grove, Ca
    basically the "newer" ones are better. The older one's have an oil slinger which can let oil leak out onto the clutch. Not sure of the cut-off date though. PM Pinhead as he knows much more than I. If you look hard enough you can find pretty good deals. I got mine off PBB for $40. It was produced in 1964 and does not have the oil slinger.
