Transfer Case Mounting Bracket
Discussion in '80-Series Tech' started by TomH, Aug 10, 2003.
  1. TomH
    TomH SILVER Star
    898
    80
    May 14, 2003
    Seattle
    I was crawling under my 97 yesterday and noticed the transfer case was replaced by the PO. I also noticed a mounting bracket on the passenger side that wasn't attached to anything. It looks similar to a motor mount or tranny mount, you know, big rubber thing with a bolt in the center. Seems like it should be connected to a mounted plate off the frame rail. The FSM doesn't mention this mount. Am I missing a bracket?
    Thanks for the help
    Tom
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Tom,
    What you are seeing is a vibration counter-weight. It just hangs out in the breeze. All of the 343 equipped 80's have one. The bus transmission 442's do not require one ::)
    Dan.
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Wow, another t-case replacment :eek:
    kurt
  4. TomH
    TomH SILVER Star
    898
    80
    May 14, 2003
    Seattle
    Thanks Dan
    Your knowledge is greatly appreciated.
    Tom
  5. irobbins26
    irobbins26
    1
    Nov 19, 2012
    Is there supposed to be a weight in addition to the rubber mount/counter weight? My bolt is sticking out about a 1/4 inch , but appears to be tight.
    Thanks,
    Ian
  6. Boltripper
    Boltripper Fixing things that are not broken...
    670
    Media:
    48
    438
    Jun 24, 2012
    Birmingham, AL
    No weight. You are good -
