Tranny question
Discussion in '40- & 55-Series Tech' started by jzilla, Apr 17, 2003.
  1. jzilla
    jzilla
    1,632
    44
    Feb 26, 2003
    Edmonton, Alberta (for now...)
    Are the tranny and transfer the same on a fj60 compared to a bj60, with standard transmission?
    thanks!
    81Bj60
  2. 73fj
    73fj Tho at sumbitch in ayer!
    1,058
    Media:
    36
    72
    Mar 16, 2003
    Grande Prairie, Alberta, Canada
    the only difference should be the input shaft,the bj is different.change the input shaft and its a boltup.
  3. zuluzeugma
    zuluzeugma SILVER Star
    1,697
    Media:
    4
    3
    Sep 11, 2002
    Midland, TX
    correct me if I'm wrong, but isnt' your BJ60 a 5 speed? all FJ60s are 4 speeds.
  4. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Wherever the truck stops!!
    BJ-60's from '83 on are 5 speed from the factory, prior to '83 all are factory 4 speeds (in Canada anyway). Earlier ones, such as my '82 have had the tranny swapped out from later models.
  5. jzilla
    jzilla
    1,632
    44
    Feb 26, 2003
    So sounds like they are the same then?
  6. zuluzeugma
    1,697
    Media:
    4
    3
    Sep 11, 2002
    Midland, TX
    I guess it depends on why youre asking. but i would say "probley"
  7. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    All tranny's on BJ's are interchangeable, in that they will bolt up to the engine (I'm not sure if BJ-4X and BJ-60 trannys can be changed) and all BJ-60 tranny's are fully interchangeable (drive shaft lengths ARE different for the 5 speed and the 4 speed as are the floor plates) BUT FJ-XX and BJ-XX are NOT interchangeable unless the input shaft is changed. The 2F and the "B" series engines have a different requirement in that part. I don't know if it is bellhousing differences or what but it is known to be different.
