tranny gasket
Discussion in '80-Series Tech' started by AZcruiser, Jul 24, 2003.
  1. AZcruiser
    AZcruiser
    332
    Jun 24, 2003
    phoenix
    I am planning on changing the tranny fluid this weekend and not sure if I should drop the pan and clean/replace the screen. The plan was to first drain and inspect the fluid and see how dirty it is,etc. to make my decision. Either way should the pan be removed and the screen cleaned or is this an overkill?
    If so, has anyone used Permatex RTV silicone (gasket maker) for remounting the pan?
    thanks
    Chris
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    You will have a hard time finding a gasket for the pan. You pretty much must use RTV.
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Chris,
    442 and 343 pans are sealed with FIPG (form in place gasket) #1281, toyota part number 00295-01281. All dealers should stock it. A tube will do a lot more than one pan, you may befriend a tech at the dealer and "mooch" a partial tube or buy a new one. The downside is you will never use all of a new one before it goes bad. It's about 20 bucks.
  4. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    So, what is the factory recommended service for the A440F transmission?
    Drain Fluid, Drop Pan, Clean Screen?
    -H-
  5. sjcruiser
    sjcruiser
    834
    2
    Apr 3, 2003
    Is the tranny filter a metal screen (cleanable), or a regular paper type (must change) ? ??? Dan ?!!!
    Frank.
  6. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Somewhere in the foothills...
    It's a cleanable screen.
    -B-
  7. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I got a tranny pan gasket from a Toyota dealer. I took it to a tranny shop and they changed the oil and cleaned the screen. I will have to look to see if the shop used the gasket or used sealant.
    kurt
  8. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Kurt,
    If your dealer sold you a transmission oil pan gasket for a "1994 Land Cruiser" I suggest you find another dealer. ::) .
    If they made such a basic mistake, I would hate to be on the recieving end of a more challenging request :eek: .
  9. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I won't know till late sunday or monday to look under the 80 to see what is sealing the tranny pan.
    kurt
    The parts guy couldn't find a #. He asked a tech what the seal was? They tech went to a gasket on the wall and said this one is used inplace of the FIPG.
    Maybe the dealer found an out source of tranny gaskets?
  10. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Chris,Dan; The local Toyota dealer in Madison WI sells a tranny pan gasket $12. It is a non toyota part but it works. Check your dealer or parts house, some one should have it. I wounder if the pan gasket is used on more than just the 80 as the dealer stocks the gasket and they don't see many Landcruisers?
    kurt
  11. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Kurt,
    The early 440's in FJ62's call for a gasket(35168-36010). As they are not supposed to be used on 91 up I haven't tried one on an 80 with a 440 or a 442. I can tell you that the oil pans have different part numbers. Sometimes the after market will cut gaskets and sell them where the factory uses a sealer. It has been my experience that the sealer works better than a gasket.
    Off to crack yokes...................... 8)
  12. AZ_Man
    AZ_Man
    12
    Jul 4, 2003
    Tempe, AZ
    Has anyone used Permatex Ultra Grey RTV instead of the ThreeBond 1281? Permatex claims it to be an OEM equivalent for Toyota FIPG 00295-01281.
  13. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I tried the import grey stuff on my rear diff acuator cover and it worked fine. I am sure it would be fine for other seals too but I will pay the $$ for the Toyota FIPG stuff, its "more better" :D
    kurt
