tires vs gears
Discussion in '40- & 55-Series Tech' started by rusmannx, Aug 25, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    i'm really hoping to go to 36's before to long when i spring it over.
    i'm on 33's right now.
    for daily driving, what gears should i go down to?
    i know i could do the sm420 conv, but will that really help me around town?
    i've been looking at the table interco has
    http://intercotire.com/html/table.htm
    and it looks like to get back to my current ratio with 36's i'd need some
    4.56's or maybe 4.88's.
    what are your thoughts?
  2. JasonH
    JasonH
    2,130
    Media:
    1
    45
    Jul 12, 2002
    McKinney, Texas
    What motor are you running?
    I've got a 2F, SM420, spring over, 4.11's and 36x14.50's. If you're motor is strong, the 4.11's will work fine on the road. I can cruise at 75 easily on the highway. If I could afford it though, I'd probably go with 4.88's as I don't drive it that much and I trailer it to the trail.
    The SM420 will actually make it worse on the road. First doesn't get used, so you use 2,3, and 4. The gap between 2nd and 3rd is huge, so you need good power to go through it. 4th is 1:1 just like what you have now so no difference there.
  3. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    My SOA 40 on 35s w/4.11 gears is perfect but I have stock 4-speed. Do the SOA and tires first. If you're not happy with performance after that switch to a four speed.
  4. wheelie
    wheelie
    64
    Apr 22, 2002
    run 35's sm465 411's works for me, my 76 is same set up sept 38's little lower wouldnt hurt.
  5. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    SM420 won't do squat for ya in town, actually will make things worse, as noted.
    IMO, install the tires and see what you think...it's easy to make that a two-step process and decide later. Since no two people have the same expectations for street driving, it may drive ya nuts, or you may not care.
    I run 38.5's on my stock 4.11 gears, but have the added power of the 350 TBI. No complaints, but my rig has the granny and is 95% trail use only anyways. For a couple hundred miles of road time, most of that between trails, I wasn't investing in gears...
