tie rod ends.
Discussion in '40- & 55-Series Tech' started by bad_religion_au, Jul 13, 2003.
  1. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    planning on doing my tie rod ends when i get my next cash hit. i know i gotta get an alighnment done by a pro, but considering swapping the new ones in myself, i have heard that it can be a pain in the ass to get them off the tie rods.
    is it hard, and what tricks do you guys use, any special tools?.
    and any traps i may fall into (putting them on backwards or something silly noobs fall into)
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    pickle fork is a must....AKA tie rod end fork. $15-20 at any autoparts store...makes the process "easy".
  3. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    so that'd replace the wood wedge with a hole and a large hammer that was outlined to me by a "bush mechanic" friend of dads
  4. woody
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    same thing, just the steel version....lol
  5. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    must be ironwood. 8)
  6. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    speaking of replacing the ends, can a bent rod be unbent or will it be weaker and need replaced?
  7. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    It would be in your best interest to replace,once you take heat to it it will weaken unless you heat and have a spare peice of steel to weld on there for a stiffener. Thats my theory
  8. 78crzr
    78crzr
    657
    1
    Apr 6, 2003
    Tomball, TX
    Hose down the threads with penetrating oil of some type for about a week before working on them. I also had to heat the end of the tie rod itself with a propane torch to get the last one out as it wasn't cooperating. I put it in a vise, hit it with the torch, and it came right out. Don't kow when your's were replaced last, but mine were original '78's and they weren't all that easy to back out. Just my $0.02 worth. :D
  9. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    I'd hose em down real good like the last guy said but be sure to break everything loose before removing. It's easier on the rig than in the vise. I changed all my ends last month and ended up putting two back on the truck long enough to work them loose. Got lucky though didn't need to torch any.
    As for straightening a bent rod, if it is a minor bend and you use the proper v-blocks in a hydraulic press, you wont compromise the integrity of the rod. If there is a dent or kink replace it.
    Don't forget to have fun.
  10. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I will need to do my TRE's soon as well, when my PO undercoated with industrial epoxy he covered the TRE's as well, I guess I need to get in there with a chisel or screwdriver and chip it away around the threads to get some PB Blaster in there?
  11. Jonathan_Ferguson
    Jonathan_Ferguson ★ is in the wrong locale SILVER Star
    1,002
    60
    Jul 2, 2003
    Glen Waverley, Victoria, Australia
    All five tie Rod Ends from Repco is $280.00 :'(
  12. FJAfrica
    FJAfrica
    205
    1
    Dec 8, 2002
    Cape Town, South Africa
    What works for me is to take 2 hammers, and hit the female part of the tie rod ends on each side at the same time. 2 hits and they just pop out every time. Mine had been in place for 8 years, and I struggled with pullers, large hammers, blood, sweat, you name it, till a friend showed me this trick.
    I put a small amount of anti-sieze compound on the taper when reassembling, so straighteneing the steering rod after a good days wheeling ;) is quick.
    ps. I picked up all 5 tie rod ends here for $60.
  13. nspctr1
    nspctr1
    2,208
    2
    Jan 5, 2003
    San Antonio TX
    yeah, you can get TRE's for around a hundred bux most anywhere but, I sprayed down mine with a lubricant and used two 16 inch pipe wrenches to take them apart. Also, mark the threads on the end that is in use so you have a guide to tell you how far to screw the new one in when you install the new ones.
  14. Radd Cruisers
    Radd Cruisers
    7,932
    70
    Sep 28, 2002
    Vancouver Island BC Canada
    I hate sweating while I work, it makes holding your beer tough.
    So that is why we pull the torch out and heat it up a bit and then throw the wrench onto it, bunchs easier. Once heated and stuck in the vice I tap the end of the tie rod which helps loosen the threads a bit more.
    Rob
  15. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    $280. wow, repco is usually expensive though, and half the time i go to repco they give me the wrong stuff. had an argument with an old guy in there 4 over an hour about 40's being sealed headlight units. finally he gave in when i lead him out to the 40, popped it off, and he tried to take it apart and shattered it.. free headlights...
