This sounds expensive...
Discussion in '80-Series Tech' started by wob, Aug 11, 2003.
  1. wob
    wob
    2,812
    685
    Feb 28, 2003
    SC
    Well, the LC crapped out on me Friday. The throttle got jumpy, hesitated 3 or 4 times, and the engine died. No CE light ever came on, and the truck would not start back. Towed it to the mechanic, and he thinks the ecu might be fried. He's not getting any feedback from his diagnostic machine to either the OCBD port in the dash, or the hook up in the hood. Gulp. :-[ :-[
    CDan, how much for an ecu for a 96?
  2. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    Be ready to grab your ankles... :'(
  3. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Mine was replaced on a 97 under warranty. If I remember correctly, at the time it was in the $1100.00 neighborhood. I really don't think there was anything wrong with it and was told by Toyota that they are bulletproof. Hopefully, it will turn out to be something much cheaper for you.
    Bill
  4. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Dunno Wob, but me thinks your parts mgr is sportin a chub thinking about it. If you need one, definitely go used.
  5. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,566
    2,892
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Wob,
    You have a PM.
    As far as used, If you can find any of the following numbers you may use it: 89661-60260, 89661-60261, 89661-60262. the '60262 is the newest number. the production range is from January 95 to August 96.
    Just a thought, is your main fuse link at the battery positive post OK?.................... :-\
    Oh, forgot. How about the circuit opening relay?
    For the benefit of the group, a new ECU is only $1300.40 :eek:
  6. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    Dan,
    Are you refering to the three wire fuse links @ the battery?
    Is one of these the feed for the ECU? I replaced mine because I noticed cracks in the insulation, and figured it could cause a problem in the future?
    circuit opening relay??? what is that? ???
  7. cruiserdan
    20,566
    2,892
    Mar 27, 2003
    Eduardo,
    Yes, the wires you described.
    The circuit opening relay is one of those magic parts in the EFI system that has an impact on how the fuel pump operates. There is also a fuel pump relay on the RH fender apron. I know just enough about EFI to start a fire but I think checking out the fuel pump circuit would be a good idea.
    Wob,
    Do any of the electrical systems work?
  8. landtank
    landtank SILVER Star
    18,424
    602
    Mar 27, 2003
    Groveland MA
    I'd definately start troubleshooting the power and ground connections at the ECU. If you don't have it there then start tracing the voltage problem. I read somewhere that about 95% of all ECU failures that were fixed with a new one was actually fixed by the act of replacing the part which in doing so resolved a bad connection problem.
  9. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    [quote author=cruiserdan link=board=2;threadid=4253;start=0#msg31552 date=1060635201]
    [/quote]
    Ouch! Like I said before... :'(
  10. wob
    wob
    2,812
    685
    Feb 28, 2003
    SC
    To answer CDan's question, all of the electrical systems are working, it just won't crank. I hope it's not the ecu, I was just preparing myself for the worst. I should find out today.
    Thanks for everyone's help.
  11. wob
    wob
    2,812
    685
    Feb 28, 2003
    SC
    Good new for me! :) :)
    Turns out it was an electrical switch in the ignition somewhere. Only gonna set me back about two bills including labor. Not great, but not $1300 either.
  12. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    wob,
    Any more specifics as to what kinda switch??
    Just wundering? relay maybe? ???
  13. wob
    wob
    2,812
    685
    Feb 28, 2003
    SC
    I'll find out later. He said it was something in the ignition?
  14. cruiserdan
    20,566
    2,892
    Mar 27, 2003
    My guess is 84450-60270. I hope he doesn't hit you more than $75.79 for it as that is published list price. ;)
