Third member interchange?
Discussion in '40- & 55-Series Tech' started by fr8train, Aug 12, 2003.
  1. fr8train
    fr8train
    100
    Jun 27, 2003
    Maryland
    Will the 3rd's from a 64 fit a 75-79 housing?
  2. Pin_Head
    Pin_Head
    13,743
    1,312
    Feb 6, 2002
    OC, CA
    Yes, but you need to drill out the holes on the casting. If you add the fine spline spiders, the later axles will fit too. If you swap flanges the drive shaft will bolt up.
  3. fr8train
    fr8train
    100
    Jun 27, 2003
    Maryland
    Great! Thanks for the info. Forgive the newbie, but which casting? Or is this self evident once I am lookin at it?
  4. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,090
    Jan 15, 2002
    Toquerville UT
    the holes in the third...the studs in the steel housing are to large.
    the 64 will have coarse spline side gears, 68-later shafts are all fine spline, so you'll need to swap out spiders (or install a locker during the process for the later shafts)
