Elk meatloaf cooked on BGE. No cooking shots but my covered smoking deck came in handy. About the time I put it on the BGE, severe T storms hit ... Sure nice to cook under cover
Pic of smoking deck from July 4
Yep, but you have to wear a smoking jacket while you use it. @elkaholic? Am I right?Smoking deck!?!?
Smoking deck!?!? I need one of those!! I've been using a cheap vertical smoker for years that turns out some of the best Q I've ever tasted. Problem is that they don't make it anymore so I'm looking at possibly the GSM or the egg as a replacement. Have you used the Weber GSM and if so, how does it compare to the egg?
If I had to buy a smoker (I got two already, a cheap vertical one from Home Depot - not al that bad) and a stainless steel one from Cabela (you can see it on a previous page, I would get one of these.
Keep it "local". Modesto. Joey loves that place anyway. Reverse flow.
KAT Reverse Flow Smoker
Those look really nice, but after using my EL Cheapo for the past 5 years I'm convinced that a basic vertical coal smoker like the one I have is the way to go. I only bought to start experimenting, but love it! GSM is about $300, which is 6X more than I paid for mine, but looks worth it based on what I've seen/read.
I'll put my Q up against anyone's!
Finally got done putting all the shots together. The long awaited video.
How many hours do you smoke them for?
Is the pink the smoke ring or from curing salt? I've never experienced it on only one side when smoking.Those look really nice, but after using my EL Cheapo for the past 5 years I'm convinced that a basic vertical coal smoker like the one I have is the way to go. I only bought to start experimenting, but love it! GSM is about $300, which is 6X more than I paid for mine, but looks worth it based on what I've seen/read.
I'm of the opinion that you'll eventually learn and master whatever grill/smoker you get. I used a regular square Aussie Grill to smoke with for years (when I wasn't grilling on it!) because it was what I had. Harder to use? Yes. But the people I feed don't know the difference. My BGE makes life easier by letting me practically set & forget for 10+ hours (but it can be a chore to get to that point some days); the Aussie had me tending it every 30 -60 minutes, and removing the grate each time to do so. Anything designed around smoking will be similarly beneficial. I'd like to get an offset barrel smoker, just for kicks, but don't have the room here.
