BamaHeel
Intergalactic Champion
You need some beads rolled in that flat sheet metal. It will make it much stronger and much more rigid.
Decided to everything the right way and purchased a new reproduction rear bed, bought a welder and took lessons on how to weld. Should have my hands full this weekend.You need some beads rolled in that flat sheet metal. It will make it much stronger and much more rigid.
Found it in Huntsville. I'm leaving the AHC stock for now because it works well and I won't go larger than these tires, which measure out at 33.2". It doesn't rub in Neutral and will be in high mode when I need the clearance, so I dont really see a need to trick it into staying in high mode all the time. I'll change the fluid and hook up a techstream I bought off amazon to make sure the system is in spec and make adjustments as needed. I am installing airbags in the back for towing. Running boards are coming off next weekendWhere did you find the LX?
You taking out the AHC or using Slee over ride until it gives out?
Anybody know of any good places down my way that can blast my body and maybe my frame too?
The auburn areaAnd down your way would be....
