Hi all,
I am in the process of installing a 2M Yeasu 2900r into my 60. I decided to do a dual antenna system. 1/2 wave off the back drivers side for when there's a lot of overhead "stuff" & a 5/8 wave in the center of the roof for open areas where distance is desirable. I have an a/b splitter to select which ever antenna I wish to use. The 1/2 wave works fine. The 5/8 wave have only the faintest reception, with lots of background noise. Note that as I don't have my license yet, I'm only using the weather channels to test the antenna function. Both antenna's are NMO mount, where I installed the PL259 connector. Presumably it's the connector that's the problem. Before I cut it off and install a new one, I'd like to test it to make sure that's the problem. But I'm not sure how to do that. I have a multi-meter. I get good continuity between the PL259 ground and the NMO mount ground for the roof mounted 5/8 antenna. I get infinite resistance/no continuity between the center pin of the PL259 and the center of the NMO mount. However, the 1/2 wave (which receives fine) tests the same.
I'm new to this, and would appreciate any input as to next steps please.
Thankyou
Thankyou
