Do you have a link to the tsm kit?
Yes, I'd like to see pix of the T'case brake and how it holds your biggie tires.
After long time debating best way to solve vacuum pump issue I decide one way 2 benefits .. bite the dust with Hydrobooster ..
Here is the adapter Elliott ( can provide info about .. no affiliation .. just pleased customer ) made to me ..
I ended adjusting holes coz for some reason my booster have other bolt pattern .. no big deal ...
It came from Chevy 2500
Here is installed in my firewall ..
Tapage,
Can you give me more information on the hydro-boost adapter, and what part numbers you used? This is exactly what I plan to do.
it's not really an adapter it's just the normal base, welded plate to fit Tencha firewall bolt pattern ..
I use an M1008 model ( Chevy .. yeah I know .. ) came in K30 / K3500 and plenty other applications .. Toy rod it's 10mm X 1.25 keep in mind the bore MC size you are going to use depending on calipers / cylinder size you have right now ..
Awesome
Is that a new e-brake cable or did you shorten the stock one and put a new end on it? If new, where did it come from?
Nice job, by the way! How big is that disc?
Will it be protected by the skid?
