TBI fuel line connections?? Woody help
Discussion in '40- & 55-Series Tech' started by ToyotaFanatic, May 9, 2003.
  1. ToyotaFanatic
    ToyotaFanatic
    10
    May 9, 2003
    Ok, doin a TBI conversion, what i am needing is the fuel fittings that connect to the throttle body! What size are they and where can i get them? Anybody have any they can sale?
    I've tried 3/8, i think they are 5/16 but not sure. Oh yea this is on a 90 model chevy truck 350.
    Thanks for any help
    Robby Pate
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    There are two different sizes. The pressure is bigger than the return. They are standard flare fittings. Take the fittings off the fuel pressure regulator and take them with you to the parts store and match them up. I don't remember the line sizes, but I just took the line off yesterday afternoon. The wrench sizes were 5/8 and 1/2.
  3. Erics75
    Erics75
    81
    Jun 14, 2002
    You should have no problem getting those, very common fittings, they do use nylon gaskets and o-rings, which you can buy in a kit.
  4. woody
    woody Internet Fireman Staff Member
    10,335
    Media:
    303
    1,093
    Jan 15, 2002
    Toquerville UT
    they are NOT standard normal fittings...14mm and 16mm, IIRC. NAPA has a TBI line repair kit available that has a 12" piece of hard line with the proper fitting on one end that you can use. Another option is a junkyard run....you can take a chunk of line with the fittings from almost anywhere in the TBI system, fuel tank, filters, etc. and they work fine. My van setup had about 5-6 different fittings I could have used.
  5. Gumby
    11,781
    310
    Dec 13, 2002
    hmmm... I don't remember them being that hard to find, but then I pull a lot of motors with the fuel lines still attached, so I probably scavenged them. As I said though, you can pull the fittings off of the TBI unit so you can match up the lines. Unless you are talking about the fittings, then you need parts from a TBI body. The good news in either case is my local pick and pull snags the injectors, IACs and TPS out of the TBI units on the cars and leaves the rest. Easy to find regulators, fittings, etc.
  6. Webster
    Webster
    236
    Feb 20, 2002
    Napa has a repair kit for each size. I thing they are call sending unit repair kits. Worked great. Just cut off one end and clamped fuel line over the tube. With the low pressure of TBI this is sufficient.
  7. ToyotaFanatic
    ToyotaFanatic
    10
    May 9, 2003
    Hey webster or woody do you know the Napa part number for the sending unit repair kit?
  8. woody
    10,335
    Media:
    303
    1,093
    Jan 15, 2002
    Toquerville UT
    don't know the part number....walked in and asked them about it tho, Belden (sp) stuff, and it was on the shelf.
    I re-used stock lines instead.
    The lines are hard to find in part cause of the metric fitting size and because they use an integrated rubber o-ring.
