TBI 350 install pics/info...
Discussion in '40- & 55-Series Tech' started by woody, Mar 26, 2003.
  1. woody
    woody Internet Fireman Staff Member
    10,335
    Media:
    303
    1,093
    Jan 15, 2002
    Toquerville UT
    [​IMG]
    For everything... http://www.ih8mud.com/tech/tbi350.html
    So far so good...first big test is this weekend in Attica.  Couple little things I may yet change, but looking good so far.
  2. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    Sweet!! Good luck with the new set-up :D
  3. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    It sits in there nice,
    okay Woody Lets get some rustoliem on it :D :D :D :D :D
  4. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    Very snazzy.
    How and why eliminate the ECT? Without an ECT you would loose enriching when cold and no choke is a big advantage to EFI. I must have misread something. ???
    I'm kinda partial to running the MAP on the firewall too. Gets it away from the vibration and heat a little.
    I ran my O2 right at the crossover connection. I'm hoping it gets hot enough, but I wanted to read both banks.
    I just ripped all the wiring back out to make my engine bay cleaner. Hopefully it will look like yours in a couple of weeks. I really like the batteries under the seat. You just solved a big problem of mine. I'll run the maxi fuse power distribution and the relay bank under there too.
  5. Gumby
    11,781
    310
    Dec 13, 2002
    I've got the GM serp belt system with the Harrison compressor too. Gonna do a tech write up on it? :D
  6. woody
    10,335
    Media:
    303
    1,093
    Jan 15, 2002
    Toquerville UT
    I'll have to double check what I kept/tossed....went from memory and my "master" diagram is here at home. Should keep that handy I guess for troubleshooting in the future....
    I left all sensors as they were from the factory. Factory O2 was on the drivers side just prior to the exhaust pipes, so it stayed there. Everything else is factory brackets, except the location of the knock sensor. In part, factory location = too lazy to change what worked form the factory. Put the O2 too far down the line and you need a 3-wire to heat it up quicker. (IMO)
    Tech for a Harrison: (real writeup pending...lol)
    Buy 3/8 pipe tap. Use pillow AC adapter from a unit that goes straight out the back. Cut flush, tap. Inline oiler is 3/8 male into pillowblock, center bolt is still metric but now allen head for clearance, output, oiler and filter are Grainger counter items. Output is 3/8 adapted to 1/4" pipe and the angle brings it to the output. For now, since there is no pressure switch/tank setup, I'll run from a dash pushbutton and will require a friend to air up tires with. Long term, air tank and switch much like my A6 setup was before.
  7. ScottFJ40
    ScottFJ40
    536
    Jan 30, 2003
    That's a very clean install if you ask me. Your cruiser is inspirational ,thanks for the pics and write ups.
  8. theo
    theo
    1,432
    Feb 19, 2002
    Nice! :) :) :)
    The MG must have taken second stage for a while. :D
  9. rocknzuk
    rocknzuk
    26
    Jun 14, 2013
    Where did this write up go?
  10. JohnnyC
    JohnnyC Long ago TLCA# 2231 SILVER Star
    14,304
    Media:
    130
    2,319
    Jun 17, 2005
    Albany, NY area
