symtoms of a bent tie rod?
Discussion in '80-Series Tech' started by peepers, Jan 15, 2009.
  1. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    I *think* my tie rod is bent. If i peek under there it looks slightly bent. I have a new Slee HD rod sitting in a box waiting to be installed. The ends are new OEM (in the last 5k miles).
    The symptoms I experienced which caused me to look under there were:
    • steering wheel way off center
    • a "dead spot" when driving straight. seems to be more noticeable at higher speeds (my caster is with in factory spec)
    As a result of these things the truck feels very dangerous on curvy roads, especially at speed.
    I am going to inspect the sector shaft or what ever its called when the new one goes in and get an alignment.
    Is there anything else I should be looking for?
  2. dgangle
    dgangle total rice SILVER Star
    4,000
    4
    Nov 24, 2004
    Heart of Dixie
    look down it/place a straight edge. you'll see it if it's bent. then measure the toe-in yourself. there are plenty of threads desribing how to do this in the 40/55 & 60 sections.
    or pay someone $69.99 to put it on a machine/measure & tell you
  3. CreeperSleeper
    CreeperSleeper SILVER Star
    6,321
    268
    May 16, 2005
    Wilsonville, OR
    If it looks bent, it is...
  4. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    i get that much. is there anything else that can be causing the issues i am seeing or are those most likely the result of the tie rod? i only ask because it seems to be one thing after another with these vehicles... :mad: (yeah - i said it.)
  5. Nay
    Nay
    4,323
    42
    Aug 17, 2004
    Colorado
    Bent rod, fragged TRE, or your nutz could be loose :flipoff2:
    There's a sadly typical correlation between a lift, big ass heavy tires, and "one thing after another". We talk about 35's like they are 31's around here, but they are still 35's.
  6. CreeperSleeper
    6,321
    268
    May 16, 2005
    Wilsonville, OR
    Pffft... 35's are small. But I'm gonna fix that!
  7. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    i do need to check my nutz. it would be one thing if i wheeled this truck regularly or hard but i drive it like a :princess:
  8. CreeperSleeper
    6,321
    268
    May 16, 2005
    Wilsonville, OR
    Sorry, I forgot the :flipoff2: in the post your quoting... :doh:
  9. CreeperSleeper
    6,321
    268
    May 16, 2005
    Wilsonville, OR
    Yes! Always check your nuts... (being serious this time.)
  10. Nay
    Nay
    4,323
    42
    Aug 17, 2004
    Colorado
    That's why it's falling apart :D
    Do check the nutz, I just about lost mine :hillbilly:
  11. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    nutz were tight. the tie rod was bent which lead to the alignment being off, however, the "dead spot" was a symptom of one of the new OEM tie rod ends being toast. a new slee HD tie rod is going in along with another OEM end and we are all good to go.
  12. Macro
    Macro
    22
    Jul 5, 2008
    New Zealand
    I knew I had one bent arm, the wheel was a little crooked and pulled a little:
    [​IMG]
    Then the other night playing on the beach had a large hit on one wheel and from then on the steering wheel was 180degrees out. So I pulled the wheel off and was greeted with this:
    [​IMG]
    My question, will an aftermarket ChroMoly set of arms like the OP has hold up to more abuse then an OEM set?
    35" Wranglers on 10" rims with a -44 offset which is 3.25 backspace I think... so theres a bit of weight hanging out because of the offset.
  13. billmiranda
    billmiranda
    290
    4
    Jul 15, 2003
    Fredericksburg, VA
    Go wth Bud-Built.. he makes an awesome heavy duty are to replace the flimsy Toy one.
  14. peepers
    peepers
    2,082
    2
    Jun 30, 2003
    the good thing about SLEE is you can use the OEM ends. not sure about bud built but with marlin crawler you cant use OEM ends.
  15. landtank
    landtank SILVER Star
    18,283
    522
    Mar 27, 2003
    Groveland MA
    Bud takes the stock joints as well. Unfortunately the last tierod I installed was an inch too long and we had already cut up the original rod to salvage the joints. That really sucked. However the next set was the correct length. Must have been a 1 off problem.
