Engine will not turn over after changing points.
This is the first time I have had to deal with points. Am I adjusting the point gap in the correct place? I used a matchbook cover in between the center of the distributor and the red stop on the points. once snug, I tightened down the screw. The matchbook cover was snug but not tight enough to rip when i took it out.
Am I totally incorrect in where I adjusted the point gap? If so, can someone show me where I should adjust it?
Or should I have adjusted the point gap at red arrow where the match cover wedges in the arm gap and then slide the mounting point enough to allow the match cover to move and then tighten the screw?
