suspension lift
Discussion in '40- & 55-Series Tech' started by cruzerdog, Mar 30, 2003.
  1. cruzerdog
    cruzerdog
    2
    Mar 30, 2003
    I would like to install a 4" lift on my 74 FJ40, with 35" tires. Any other mods needed besides extended brake line, dropped pitman arm ? Is steering column a problem? I have Saginaw pwr. steering. Do the diffs. need to be shimmed for drive-line angle? Any input is appreciated. Any input on Downey 4" springs? Alex
  2. theferg
    theferg
    2,251
    Media:
    2
    84
    Dec 22, 2002
    wandering the wild wild west
    I would indeed shim the springs--it will help the pinion angle and keep your steering from too much wander. With 4" lift you would want around 4 degree shims. You shouldn't *need* a drop pitman arm....
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Don't know about the Downey's, I'm going skyjacker kit from my local 4wheel parts performance center.  They will match any price I find, and will include shocks if I find another place that includes shocks. (Their site includes shocks, so that is what I will use). $610 with
    Front Springs
    Rear Springs
    Eliminator Front shocks
    Eliminator Rear Shocks
    Spring Bushings
    Spring U-Bolts
    Woody and Halo didn't have any complaints, and others like them too, and its fairly inexpensive so thats what I'm getting.  How much are the Downeys for comparison?  The softrides by themselves are ~ $70 apiece. I know that I need extended brake lines, but 4x4 parts wholesalers doesn't carry them for cruisers. How long will I need and where can I get them? Stainless braided is what I want correct?
  4. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    Someone posted a few weeks ago about the SkyJacker spring sale at TPI. I think they said they were $75 each. Even if they are stiff, it would probably ride better than my flat OEM springs.
  5. cruzerdog
    cruzerdog
    2
    Mar 30, 2003
    Downey offroad has the springs and bushings for $378.00. Also have the braided steel brake lines, 38.00 for the single line.
  6. brian
    brian SILVER Star
    7,342
    769
    Feb 7, 2003
    lebanon,pa
    i don't know about their cruiser springs but i have a set of 3" springs on the rear of an 86 pick up.
    they faded real fast.
    5 yrs after installion they've saged atleast 1-1.25. the rear sits quite lower than the front(front springs are downey torsion bars with rancho arms).
  7. brian
    brian SILVER Star
    7,342
    769
    Feb 7, 2003
    lebanon,pa
    i have a set of downey 3"springs on the rear of an 86 pu.
    put them on 5 of so yrs ago, in that time they've saged almost 1.5"'s.needless to say the rear sits quite lowwer than the front(downey torsion bars rancho arms).
    i never carried anything of weight or did any towing.
  8. theferg
    theferg
    2,251
    Media:
    2
    84
    Dec 22, 2002
    Sheesh, did everyone get that...?[​IMG]
  9. ScottFJ40
    ScottFJ40
    536
    Jan 30, 2003
    Hey Brian, how long did you have them? :D
  10. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    I run the bds 4" springs, they have the caster built in like the ome's do. They have a lifetime warranty, their shocks are nice and squishy. I run 1" over stock length shackles to let the springs flatten...
  11. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    You may want to try an Earl's distibutor for the brake line. I picked mine up from a shop in Atlanta for $15.
    Barnettperformance.com
    The part number I used is:
    63070726
    10mm Male - Female - 26" long
    If you need different lengths, the last two digits are the length.
    Hope this helps.
  12. LT
    LT
    1,783
    26
    Apr 8, 2002
    Portland, OR
    I have the 4" downey leaf springs on my 76 FJ40 right now, they ride great and flex well for a SUA. I haven't had the sagging problem yet, but i've only had them on since october. So far no complaints... i probably won't have them long enough to know if they sag or not cause i'm seeing SOA in the future :D
  13. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    I would suggest the Skyjackers. I have them and they are not stiff at all. Just get a good set of shocks when you get your lift. Shocks can make or break a decent ride. Good luck!
  14. brian
    brian SILVER Star
    7,342
    769
    Feb 7, 2003
    lebanon,pa
    the forum was acting funny yesterday,it would'nt let me post.
    and then apparently it posted both :-[
  15. ScottFJ40
    ScottFJ40
    536
    Jan 30, 2003
    It's cool Brian, we forgive you since you have 1700 toyotas. :D
