stuck thermostat, or...?
Discussion in '40- & 55-Series Tech' started by swank60, Jun 11, 2003.
  1. swank60
    swank60
    1,483
    217
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    okay, I know the drill...if the temp goes up after you shut off the engine, it's a stuck thermostat...right? But what do you do when you've changed the thermostat, rebuilt the carb, adjusted your float, etc - and checked everything else...what's next? Is there anything else that can cause this?
    Boiling the contents of my carb each time I stop the truck is no bueno...
  2. dylan
    dylan
    246
    Dec 23, 2002
    my 76 did something like that and it was the radiator (clogged)
  3. Erics75
    Erics75
    81
    Jun 14, 2002
    I think its pretty much the norm for it to heat up after you shut it off, the coolant stops flowing, fan stops etc. Do you have an insulator under your carb? I just wondering if its missing or replaced with something else.
  4. SwampRat
    SwampRat
    31
    May 8, 2003
    on my 78 near stock 2F motor.....it has a coolant line that goes into the intake to either warm it when it is cold or keep it cool when hot........either way there might be a gremlin hiding in there somewhere.
  5. zuluzeugma
    zuluzeugma SILVER Star
    1,697
    Media:
    4
    3
    Sep 11, 2002
    Midland, TX
    Is your carb cooling fan working? IF its not, the heat of your engine pluss summer temps together will cause this. Your carb fan should run 25-30 mins after you cut the engine off. My fan wasn't working, and as a result it was real hard to start cause all the gas was evaporating out of the carb. Check see if the fan is running. IF its not, tell us, and 50 million people will tell you what to look for in less than an hour.
  6. swank60
    swank60
    1,483
    217
    Aug 26, 2002
    hmmmm...things to think about.
    I know it's not the radiator either. I replaced that a few months ago - the old one split it's seams (as the Toyota rads are famous for)
    I'll check the intake coolant line...haven't pulled that off...and I've read somewhere that that line is a problem.
    I'll check the heat sheild as well. (although the heating is way above normal - it almost goes up to the boiling-over point)
    thanks for the input!
    zuluzeugma - you know what - it isn't working! I was going to test it this weekend and find it's relay etc...time for a new post?
