Stock 1975 FJ40 Tire Size vs Motor size
Discussion in '40- & 55-Series Tech' started by petescoffee, Dec 29, 2002.
  1. petescoffee
    petescoffee
    1,823
    19
    Dec 29, 2002
    Walnut Creek, CA
    I am a new owner of a stock FJ40 and am about to begin some modifications.
    Will the 2F with 4.1 dif be adequate for 32's or 33's.
    Or should I start over with a Chevy 350. The motor only has 61,000 miles on it and I was thinking of overhauling it.
    I am planning on installing a 2 1/2" lift.
    The FJ40 will be used in higher elevations around Telluride, Colorado.
    Any Information would be helpful.
    Thanks,
    Petescoffee
  2. notaf-ingjeep
    notaf-ingjeep
    210
    Feb 17, 2002
    monkey town, P.g.c. Utah
    I run a built 2f with 4.11 and 35" tires and it does very well. A stock 2f will be fine with 32" or 33" tires. If you feel under powered, the added cost of puting a 350 in your crusier you could instead add some upgrades to your 2f or put some 4.56's in your axels. Personally i think cruisers are best if they are still toyota.
  3. petescoffee
    petescoffee
    1,823
    19
    Dec 29, 2002
    Walnut Creek, CA
    Unfortuantely I am in California and am limited on the number of modifications I can do to astock vehicle.
    Does anyone know what can be done and still maintain my smog legal status? Or of a good resource for that information?
    Based on other post the keep original motor vs swap to chevy is quite common. I am still up in the air but need to decide soon.
    Petescoffee
  4. tennfj40
    tennfj40
    28
    Apr 29, 2002
    well I guess I will jump in here and put in my .02. Keep it stock, 61k dont rebuild it, . that motor will pull tires upto 35inch. Would not go the 350 route, you have a toyota not a chevy.(not to take away from anybody who has done this because it works very well. In my opinion it takes away from orininality. kind of like when these guys put rockwell axles under a tube frame with a big block and put a jeep body on it and they call it a jeep, EXACTLY WHICH PART IS A JEEP! Sorry to use such language on this site I mean a heep.
  5. petescoffee
    petescoffee
    1,823
    19
    Dec 29, 2002
    Walnut Creek, CA
    I have rebuilt a few other cars including a CJ2A and always have kept them stock. What about information or resources for maximizing the 2F?
    Any thought on running the 2F in High elevations?
  6. tennfj40
    tennfj40
    28
    Apr 29, 2002
    as far as getting performance parts for a 2f they are out there, I would keep it stock and put efi on it, that would be the best performance mod. you could do.
  7. petescoffee
    petescoffee
    1,823
    19
    Dec 29, 2002
    Walnut Creek, CA
    Regarding the EFI any recommendations or results from someone running it on a 2F? Are they tempermental at all?
    EFI would probaly eliminate my concern in the high elevations.
    Petescoffee
  8. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
  9. petescoffee
    petescoffee
    1,823
    19
    Dec 29, 2002
    Walnut Creek, CA
    Can you give the linke for the 2F EFI again. It lead me into internet outerspace.
    Thanks
  10. tennfj40
    tennfj40
    28
    Apr 29, 2002
    you can go to the tech on this site or do a google search, there are companies that make a kit $1400, or you can do a junkyad efi
