Stihl MS180 C-BE boggs down
Discussion in 'Workshop and Home Improvement' started by MaplesugarRick, Apr 16, 2009.
  1. MaplesugarRick
    MaplesugarRick
    3
    Apr 15, 2009
    I'm having trouble with my Stihl MS180 C-BE chainsaw. The engine boggs down under a load and when just reving the saw. I have replaced the spark plug (properly gapped), rebuilt the carb, replaced the fuel line and the fuel filter, cleaned out the chain brake and the clutch and cleaned the fuel tank air pressure stabilizing valve. Also cleaned muffler and replaced spark arrestting screen.All with no luck. Getting frustrated. Anyone have any suggestions?
    Thanks
    Rick
  2. fj40charles
    fj40charles
    3,040
    195
    Dec 7, 2002
    Texas
    Waiting on the Chainsaw KING to reply.
  3. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    What length bar?
    Are you at any elevation?
    What size chain? Does the front raker in front of the actual cutter bent over or is it straight up and down?
    Have you ever adjsuted (filed) the rakers? Did a shop sharpen the chain or do you do it yourself?
  4. MaplesugarRick
    MaplesugarRick
    3
    Apr 15, 2009
    It's 14in bar and chain, with a new chain on the saw. my elevation is 640' above sea level. I do sharpen the chains myself using an Oregon 511A. The rakers are angled low to high with the high end in front of the cutter. They are Sthil chains. I guage the rakers and grind them when necessary.
    But I believe my problem is connected to the carb or fuel system, because the saw falters or boggs down when i'm not actually cutting. The engine will rev up when I pull the trigger, but after a few seconds rpms will drop about 1/2 then rev back up again. Almost like I flipped the kill switch for a micro second.
  5. D'Animal
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    Is the saw new or a few years old?
  6. Michael Hanson
    Michael Hanson
    7,653
    Media:
    3
    23
    Oct 30, 2007
    Plano texas
    Carb.( 2 cents) the new gas seems to clog small motors Mike
  7. D'Animal
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    The new fuel doesn't really clog the carbs. The new fuel cleans everything really good and what the fuel cleans ends up in the fuel filter or the carburetor screen.
  8. MaplesugarRick
    MaplesugarRick
    3
    Apr 15, 2009
    Found the problem. Using 10x magnifying classes I discovered a tiny piece of fiber partially clogging the high speed jet in the carb. removed it and saw functions perfectly.
    Thanks all for your input.
    Rick
  9. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
    I think I am having the same problem with mine. How did you get the carb off? It's looking a little tricky to me. I have never worked on anything this small. I took it to the shop for repair, thinking it was the carb but they told me I ran straight gas through it and seized it up. I didn't run straight gas through it and it isn't sized up so I am wanting to dig into the carb myself. All help is appreciated.
  10. splitshot
    splitshot Head cook, Bottle washer, and Peace keeper. SILVER Star
    6,431
    Media:
    11
    549
    Nov 17, 2006
    Rodent Central, Az
    "Seized" may mean a scored piston/cylinder, have you loaned it to someone?
    Welcome to mud BTW.
  11. D'Animal
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    Remove the muffler. It requires an 8mm or 5/16" nut driver or wrench.
    Look in the exhaust port.
  12. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
    no never loaned it out. After I got home I remover the spark plug and looked in there and everything looks good. It idles fine but after you rev it up it looses power. I have ran many 2 stroke motor cycles and atv's and feel as though its a carb problem. The muffler looks easy enough to remove but I want to check out the carb. They wrote it up as I ran straight gas through it and seized it. I ask if they checked the carb and they said no. I told them that I ran Polaris gold synthetic in it, which I used to use in my drag bike years ago, service manager says stihl says that that is an unacceptable oil. So I am just wondering how to go about pulling the carb off the easiest way to check out the jets. Thank You for all replies.
  13. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
    Just took off the muffler and it all looks good. Don't know how to post a pic of it on here.
  14. D'Animal
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    By a silver star and you can post unlimited pictures.
    Is the spark arrester screen plugged?
    What color is the residue on it?
  15. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
    Its all clean just a blackish color. A couple of the small holes were plugged with what seemed like excessive oil, but once I blew on it it was clear. All small holes free of residue.
  16. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
  17. D'Animal
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    Now take and post a picture so we can see the exhaust side of the piston.
    In you picture the piston is all the way down or BDC.
  18. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
  19. D'Animal
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    Move the piston up in bore a bit more so we can see the piston below the ring and turn your flash off.
  20. naturalite
    naturalite
    25
    May 29, 2010
    Dallas, Tx
