stiff steering normal after bearing repack?
Discussion in '80-Series Tech' started by semlin, Apr 3, 2003.
  1. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    OK, I’m back on the road with repacked front axles (wheel and pivot bearings were all good), a rebuilt cv joint and a straightened drive shaft plus my third alignment in three months. Visa has got me covered (Ouch). Has anyone else found the steering just a tad stiff after this kind of work? I feel like I’m driving an M1A1 out there (or a Leopard II since I’m in Canada)
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Do you also have the 120mm smooth bore cannon? It is particularly effective with DU penetrators....... :eek:
    How much stiffer? If your trunions were loose before and they reset the pre-load properly that would stiffen it up some....Did they remove the knuckles? Sorry to sound like the Spanish inquisition.......Just thinking out loud (and scoring another 8))
  3. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    In Canada our tanks are strictly for humanitarian purposes so they don't use actual ammunition in the guns as this might hurt someone. Also our tanks don't move because this requires that they use fuel which might harm the environment. They do make good planters.
    Let's see, with loose (1) being the steering on a 76' Royal Monaco Brougham station wagon and stiff (10) being a 1966 Mercury Ranger pickup with manual steering, I'd say it has moved from a 5 to an 8.
  4. landtank
    landtank SILVER Star
    18,423
    596
    Mar 27, 2003
    Groveland MA
    I didn't notice any difference after the repack. However it was done before failure and only the trunions were replaced.
    Rick
  5. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Hmm, DU! &nbsp:Dan, you give me flashbacks to my Los Alamos RCT days....
    -H-
    (Shamelessly getting another post on a Friday... :slap:)
  6. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    -H-Re: stiff steering normal after bearing repack?
    -H-
    Next time I'm in Los Alamos for a match, I plan to stop by The Black Hole and see if I can pick me up a chunk. I wanna stick it in the garden to see if it will keep the rabbits out of the beets....... :dunno:
  7. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Oh, Simon,
    S**t, forgot about you......Sorry..
     Maybe the Birf is Tight from the rebuild...Run it for a day or two and see how it shakes out........Dan
  8. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Uh, Yeah, I hear rabbits don't like beta emitters ??? :)
    -H-
  9. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Before I did my knuckle job I hated the way it steered. It was stiff and I had to use my hand to steer going down the road. I took the knuckle apart and the steering bearing were so bad that when I turned the steering arm it would lock in three places. The bearing were long gone. I now can steer with one finger. It sounds like who ever did the job didn't' use a spring guage to test the load on the bearings. There are shims to correct for the bearing load or preload, I forgot the correct trem. I installed new newfields too and it is not stiff. The same is for the fj60 with a new steering damper OME.
    kurt
