Steering/suspensio bushings..what to replace??
Discussion in '80-Series Tech' started by Cancruiser, May 16, 2012.
  1. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    Calgary, Alberta - Canada
    I'm going to install Slee caster correction bushings + the rear (chassis side) leading arm bushings. I thought while I'm in there maybe I should replace as many steering/suspension bushings as possible (most are due anyway).
    The questions is, what do I replace? I am looking for bushings that are easy to access and quick to change. Any suggestions or pictures would be great..
    :cheers::cheers:
  2. powderpig
    powderpig SILVER Star
    1,011
    7
    Jul 12, 2005
    Boulder Foothills, CO
    Age is not a much of an issue to me as miles and how hard it may of been worked over the years. If the truck was mostly a highway cruiser with little to low miles off road. Has not seen much in the way of Mag Cloride. Then I would not replace anything else. But the best way to know is to look at the bushing and seeing if the inner steel insert is pulling way from the rubber.
  3. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    The thing is, the history of the truck is unknown to me. I have bought it 4 years ago (imported from Japan) and it is already 23 years old, so probably rubber bushings have dried/perished just from sitting around.
    Plus, I have some steering issues (wandering, looseness..etc) so any little bit helps.
    I looked up the FSM and so far all I can find are these two in the picture below. Are there any other ones?
  4. Akella
    Akella SILVER Star
    1,354
    28
    Apr 14, 2010
    London, ON Canada
    here is the list of all the oem suspension bushings with part numbers and required hardware per fsm.
    Parts list:
    BUSH SUB-ASSY, LEADING ARM, NO.1 48702-60050 x4
    BUSH, LOWER ARM 48061-60010 x2
    BOLT HZJ80 90119-16003 x4
    BOLT HZJ80 90105-18006 x2
    BUSH SUB-ASSY, FRONT LATERAL CONTROL ROD48706-60030 x2
    BOLT HZJ80 90119-16003 x2
    BUSH,STABILIZE 90385-11021 x4
    BUSH, FRONT STABILIZER BAR, NO.1 48815-60070 x2
    BUSH SUB-ASSY, LOWER CONTROL ARM 48702-60040 x4
    NUT J790 90170-18007 x9
    BUSH SUB-ASSY, UPPER CONTROL ARM 48702-60031 x4
    BUSH SUB-ASSY, REAR LATERAL CONTROL ROD 48706-60040 x2
    BUSH, STABILIZER(FOR REAR) 48815-26020 x2
    if you will install caster correction bushings then you dont need the first one on the list
  5. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    Thank You... Thanks You.. Thank You..
    :clap::clap::clap:
    :cheers::cheers::cheers:
  6. Akella
    Akella SILVER Star
    1,354
    28
    Apr 14, 2010
    London, ON Canada
    let me know if you need a set.
  7. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    Do you have a set for sale??
  8. baja1d
    baja1d
    656
    Media:
    3
    4
    Feb 19, 2010
    Littleton, CO
    Same question. Mine is a '94 if it makes a difference.
  9. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    I think it does make a difference. Mine is a '91 and found a couple of bushings in mine are different from what Akella posted up there. But the majority are correct.
  10. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    So, I ordered the front (and some rear) bushings. But to my dismay, I found the OEM ones (front and rear) don't fit the stabilizer bar that is on my truck (see item # 48815 circled on the drawing in post #3 above). My front and rear stabilizer bar don't seem to be stock and have a larger diameter (see pics below). I measure the diameters as:
    Front: 1.217" (30.91 mm)
    Rear: 1.0905" (27.7 mm)
    I think they were part of a lift or upgrade by the previous owner. Now what do I do? Where do I get rubber bushings for them??
  11. IanB
    IanB
    2,387
    377
    Jan 23, 2010
    Winnipeg, MB
  12. Akella
    Akella SILVER Star
    1,354
    28
    Apr 14, 2010
    London, ON Canada
    Sorry guys forgot to reply to this thread. Here is sale thread for the bushings i have [CA-ON] 80 series OEM full suspension bushing kit with Toyota required hardware I can modify kit to fit anybodys needs.
    x2 on energy Suspension bushings for oversized sway bars.
  13. Cancruiser
    Cancruiser
    608
    1
    Oct 6, 2008
    Thanks for the Energy Suspension link..
    Sorry, Akella, I didn't see your offer for the bushings at the time when I ordered. I would have rather bought them off you.. But, I may still take the bolts and nuts and a few other ones from the rear that I didn't get. Let me make a small list and PM it to you.
