Starter Problems with 94 Land Cruiser FJ80??
Discussion in '80-Series Tech' started by kdubendorf, Aug 9, 2009.
  1. kdubendorf
    kdubendorf
    24
    1
    Apr 8, 2006
    Berwyn, PA
    I've been having intermittent starting problems on my 94 Land Cruiser (338K miles) for about 6 months now.
    99 times out of 100 the truck starts right up when it's been sitting for at least 30 minutes and it even starts about 95% of the time when it's warm.
    If I run the truck and turn it off but leave the accessory switch on for a few minutes the truck won't start. I get a clicking noise when I turn the key, it sounds like the fuel pump is on... the engine won't turn over. Usually if I spend 1 to 4 min turning the ignition key off and on (once I've shut everything off) the starter eventually turns the engine it fires right up. This will also happen if I stop the truck and don't open the door (power is still on to the windows and doors then).
    I can pump the brake and move the shifter but it doesn't seem to make any difference in how quickly the truck starts.
    One time I got out and pushed the car a few feet...that seemed to help.
    I'm guessing that I may be looking at a starter. If that's the case do I need to get Toyota parts or will others do? Could anything else be causing these symptoms.
    It hasn't bothered me too much but it does phase the rest of the drivers in the family :)
  2. beno
    beno 33030-60450 Supporting Vendor Moderator
    18,542
    5,635
    Aug 28, 2004
    Covington, GA
    You might be just looking at a rebuild of the internals at roughly $30 in parts.
  3. kdubendorf
    kdubendorf
    24
    1
    Apr 8, 2006
    Berwyn, PA
    Is that something I would get the local mechanic to do? They seem to like to replace things these days. Is this available as a part from the dealer?
  4. beno
    18,542
    5,635
    Aug 28, 2004
    Covington, GA
    You could do this in twenty minutes on your bench at home. Really--it's pretty simple and has been documented here.
    Yes, the parts should be available from a dealer, but most dealers don't carry too many LC parts. You would probably be better off from one of the vendors here.
  5. 4x4CPOSEADOG
    4x4CPOSEADOG
    2,580
    5
    Jul 14, 2004
    on the right coast
    You may want to read this write up compliment of good ole George: Starter Motor Contacts
  6. zombified
    zombified
    116
    Jul 28, 2009
    Dela-Where?
    sounds like the brushes are sticking a bit. I drove a jeep with this same issue for about 3 months. Instead of just trying to start the truck, i'd take a long socket extension, line it up on the the starter case and give it a light smack with a hammer. it'd free it right up.
    short answer to your question as stated above is rebuild or replace your starter.
  7. dace voit
    dace voit
    180
    3
    Jan 25, 2007
    Winter Park, CO.
    Probably the starter, but...
    check your contacts for looseness and corrosion. I've seen hidden corrosion in the strands of the wire at the battery and a loose connection at the starter cause these kinds of problems.
    NLXTACY likes this.
  8. rexman
    rexman
    334
    1
    Jan 14, 2009
    sofaroffroad>U.S.A.
    starter help
    have the same problem with my 91 fj80,cold starts right up,hot 99 to 1 chance it won't start,turn the key a number of times or let it cool down and it starts,where on here can i get a rebuilt kit,or buy a new or rebuilt oem starter
  9. softweyr
    softweyr
    1
    Sep 20, 2010
    San Diego
    Same problem, '93 FZJ80
    My Cruiser is having the same problem at 223K miles. I talked to a local shop this morning, they want $75 labor and $250 for the 2.2KW Bosch starter. Certain I could do better, I took to Google. Turned up this fun article asap:
    ToyotaOffRoad.com - The Starter
    I was a pretty fair shade-tree mechanic in my youth, and I found the exact starter he's referring to at O'Reilly (may be Checker or Kragen in your neighborhood) for $129. I'll be biting off this one on my own.
    Question: can I get the security code from a dealer from the VIN number? I've never had the key tag for Big Cruiser, we got him used in 98 when he was a very young 5 years/ 91K miles old.
  10. Mark Grant
    Mark Grant
    85
    Mar 17, 2009
    Your Mum's House, CA
    Thank you so much for the article. That panel to remove in the fender well just kinda hides there and it mentions nothing of it in the FSM, BASTARDS!:cheers:
  11. jvazquez53
    jvazquez53
    2,925
    20
    May 6, 2007
    San Juan Puerto Rico
    I did the same with my 80, but used a wood pick handle that I carry as an "attitude adjuster" for other people. kept doing it until one rainy night. Replaced the starter and two weeks later started to do the same. The way I solved: rigged a Ford stater relay, and a year later, truck runs fine!:steer:
  12. jdubes
    jdubes
    6
    Nov 18, 2014
    I just fixed my start this way. I used an long bar attached to my socket to get the top bolts off. It was a 15minute job. Both came off real easy with i extend my socket with bar to increase my force.
  13. Boltripper
    Boltripper Fixing things that are not broken... GOLD Star
    662
    398
    Jun 24, 2012
    Birmingham, AL
    With you being in Pennsylvania you need to meet Beno (Onur) @beno above in your thread. He can get you Toyota OEM parts for your truck at a better price than your local dealer and is close (In Georgia)... You'll also have a great resource if you have parts / mechanical questions and he wont Steer :steer:you wrong.
    Onur: 505.944.5081// onurazeri1@gmail.com
    He's a supporting vendor here on MUD..... Support your vendors !! :cheers:
    beno likes this.
