Starter/flywheel grinding noise
Discussion in '80-Series Tech' started by silverhorse, Mar 26, 2010.
  1. silverhorse
    silverhorse
    921
    17
    Feb 7, 2009
    Pensacola, Fl.
    When I engage the starter I get a grinding noise at the starter/flywheel. Anybody else had this issue? TIA
  2. hobbes
    hobbes SILVER Star
    440
    10
    Feb 2, 2002
    Naples
    Had it intermently. Think it was the plunger. Do that and starter contacts if you haven't. I had to throw a starter at it due to time constraints. Problem went away.
  3. limerence
    limerence
    327
    Oct 26, 2003
    San Jose, CA
    I'm having the same issue. Gotta fix the HG first and then deal with it after.
  4. cc93cruiser
    cc93cruiser CRUZAHEAD
    1,690
    Media:
    6
    74
    Sep 7, 2004
    Hayward, Ca.
    I just started having this problem today... At first it caught me off guard. I thought I had turned the key while the car was still running. But I confirmed it was off. Started it and did it again... I have turned off and started the cruiser a hand full of times and hasen't done it since. My question is, if I don't fix replace the starter fast, can this cause damage to the teeth of the flywheel? Should I buy a new unit or replace the contacts and plunger?
  5. cc93cruiser
    1,690
    Media:
    6
    74
    Sep 7, 2004
    Hayward, Ca.
    *One more question.... Does a bad Plunger or bad contacts cause the teeth on the starter and flywheel not align right, hence the grinding noise? Just trying to figure out why the grinding noise?
  6. ppc
    ppc M Go Blue
    1,385
    175
    Aug 18, 2003
    Nashville, TN
    With the worn contacts the plunger sticks to the contacts and the starter continues to run. The starter runs slower than the running engine which is causing the noise. You need to disconnect the battery to stop the starter as the starter will burn up vwry quickly. Sometimes a good wack from a hammer on the starter will free the contacts and plunger. It is only a matter of a few more starts and that remedy will no longer work. Get the contacts and plunger replaced otherwise the starter is going to be major $$$
  7. cc93cruiser
    1,690
    Media:
    6
    74
    Sep 7, 2004
    Hayward, Ca.
    Thanks Phil. However my starter is not sticking while the engine is on, but when I attempt to start I get a loud grinding noise. I then let off the key, try to start again, and everything is fine....
  8. cc93cruiser
    1,690
    Media:
    6
    74
    Sep 7, 2004
    Hayward, Ca.
    Can anyone confirm? Or is the grinding noise at start up possibly a broken flexplate/flywheel or the little drive gear on the starter.. Either way, I might as well check the flywheel... Does anyone remember what size socket to use to turn the crankshaft nut to rotate engine (to inspect the entire flywheel)? Sorry for all questions, just trying to understand what I have to buy, a complete starter or the contacts/plunger (that's if the flywheel checks out...)
  9. jonheld
    jonheld
    6,014
    747
    Dec 8, 2006
    New Jersey
    Strange but true...
    Yesterday I had a no start that caused me to pull my hair out for awhile and in doing so I came across the exact same noise. On mine, the starter would engage and the motor would begin to crank. Then as the motor starts to catch there is this horrid low frequency grind just for a moment. When I heard this I released the key and tried to start again. It started without issue. On a warm start it wouldn't happen. On a cold start it would happen almost every time. I came across this as I was tracing out vacuum lines and I inadvertently swapped 2. When I reversed my mistake this problem went away. When I swapped them back, the "starter" noise returned.
    Obviously the vacuum lines have nothing to do with the starter, but they have a lot to do with fuel pressure. What I think is happening is a backfire rather than a grinding of the flywheel.
    And yes, I know how crazy this sounds.
  10. EMartin
    EMartin
    7
    Jul 14, 2009
    I just replaced my starter yesterday. Got the new one in and turned the key. When the engine started I got the loud squeel, grind etc. A sound you would expect maybe if you turned the key while the engine was running. Sometimes you have to shim a starter to get the allignment with the flywheel correct but you are not supopsed to have to do that with these rigs. I am returning the starter for another new one and will post if the problem is fixed. It seems like the starter is not dis-engaging quick enough. Mine does it every start.
  11. edog's 80
    edog's 80
    348
    1
    May 13, 2008
    Boulder, CO
    I had the same problem. A new plunger and contacts did not solve it. Only switching out to another starter solved it for me. I looked at my old starter and it appears that some of the teeth on the bendix? apparatus were worn, whatever it is that connects to the flywheel.
