Squeaking Heater Fan
Discussion in '100-Series Cruisers' started by E&TMcD'sLC, Dec 14, 2008.
  1. E&TMcD'sLC
    E&TMcD'sLC
    71
    Mar 14, 2008
    Denver
    Anyone know how to fix this? Intermediately, my front heater fan starts to squeak. When I turn up the fan, it usually stops. Can I clean it or is this beginning of the end of my blower motor?
  2. Trunk Monkey
    Trunk Monkey Moderator
    7,963
    285
    Apr 27, 2003
    Salt Lake City
    On my old 4Runner, the brushes in the blower motor were a Toyota serviceable item. I had the same issue with it squeaking, replaced the brushes - problem solved.
  3. E&TMcD'sLC
    E&TMcD'sLC
    71
    Mar 14, 2008
    Denver
    thanks. Is there a diagram or instruction guide posted anywhere?
  4. Trunk Monkey
    7,963
    285
    Apr 27, 2003
    Salt Lake City
    Not that I've seen, the FSM probably has something. You may be able to find the part on the toyodiy site.
  5. coryc85
    coryc85
    195
    1
    Jun 18, 2007
    South FL
    I live in S FL, so my ac is on pretty much every day in my truck. The fan definitely makes a little bit of noise, almost like a little ticking sound. I have tried lubing it with silicone spray, also tried WD. My next thought is to dry some dry graphite because the noise always comes back in a day or two. I removed the whole blower motor (three screws on mine and it drops right out), cleaned the fins (you might want to check for debris in yours), but the noise always comes back. I don't see any way to replace the brushes or bearings, you might have to replace the whole blower if it bothers you. I'm going to let mine run until it stops working.
  6. E&TMcD'sLC
    E&TMcD'sLC
    71
    Mar 14, 2008
    Denver
    thanks. I'll take it apart and work on it when it warms up. It was -15 degrees out this morning in Denver....:mad:
  7. ShottsUZJ100
    ShottsUZJ100
    8,690
    9
    Apr 2, 2003
    Tucson, AZ
    Replaced mine due to massive dirt/dust from 4-wheeling. EZ...$150 under the glove box.
  8. Liam
    Liam
    4,549
    Media:
    31
    4
    Feb 10, 2005
    in the nappy dugout
    my rear heater started squealing Saturday....i turned it up and it stopped. Hasnt made another squeal since...
  9. Crain
    Crain
    123
    Nov 7, 2007
    Parker, CO
    Did you make any headway with this. My heater fan has started making a ticking noise (on all settings).
