sor ring & pinion kits
Discussion in '40- & 55-Series Tech' started by rusmannx, Sep 6, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    are these prices per axle does anyone know?
    why do i have to buy an installation kit along with it?
  2. nuclearlemon
    nuclearlemon not an addict Moderator
    15,585
    Media:
    87
    404
    Jan 30, 2003
    meh-ico, colorado
    price should be per axle whenever you see them unless they list a kit. installation kit is good because bearings and shims may be worn and not meet tolerances. also, be sure to ask if they are course or fine spline pinion. some companies are only offering fine and you have to buy a companion flange also.
  3. Landpimp
    Landpimp GOLD Star
    14,687
    869
    Mar 14, 2003
    PNW
    pretty darn vague question.......what prices, what ratio, what part number?
    if the price is the $200 range than it's per axle and in am sure it is per axle, that how they are almost always listed.
    look around SOR some more I KNOW they have just the R&P with install kit.
    I belieive the 4.88's are $170ish just for the gears.
    John H
  4. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
  5. Pin_Head
    Pin_Head
    13,747
    1,317
    Feb 6, 2002
    OC, CA
    The 4.56 kit for '78 at $179 looks like a smokin deal, but probably doesn't come with the flange. The extra money for the flange for the other years is not a good deal because you can use a mini truck flange and just drill new holes for your drive shafts. You need an installation kit if you want new bearings. It is hard to get the inner pinion bearing off intact without a press. You will need a crush sleeve to set the pinion preload and an extra one if you screw it up the first time. Most aftermarket R&Ps are designed to use crush sleeves.
  6. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I bought a R&P from Randy's, they sent me fine spline, I did get an adapter flange, but the pinion gear was a different length and nothing fit right. :mad: Hence the 3rd member purchase from David. So I'm not sure that a companion flange is all you need to make a fine spline R&P work in a previously coarse splined rearend. ???
  7. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    AFAIK aftermarket cruiser R & P only come in fine spline. Correct me if I'm wrong.
    Dave
  8. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    that's all i've seen as i've looked around.
    this is why i'm thinking of cutting down a for 9"
