orangefj45
Supporting Vendor
- Thread starter
- #61
Other side of first generation case half.
Hi! I also use H55F on my LC60. How do you take out the vacuum pump and change to mechanical linkage? Thank you!Completed combo with vacuum shift case converted to mechanical linkage. I rebuilt this particular h55f since it came with a 1HZ engine we're transplanting into an FJ60.
What do you mean "shifter bolt" on the transfer case? The pivot for the transfer case shifters are on the transmission.
So, back to different case conditions. This is a 9/84 splitcase with 34mm idler. It has the provision for the oiler cup, and a hole that should have been plugged when the h55f was mated to it.
AFAIK, the case was original. And, yes, it was bolted to "no spacer" H42.
Bringing this thread back to life. I have a 40-series top cover at the shop right now. Will post some pics to show the difference between it and the 60-series cover.
Georg @ Valley Hybrids
Somebody just posted nice side by side pics in another thread....
Here they are, courtesy of Toyoland & Lostmarbles:
