I can only do what I know, so Im limited
Can you post up some more details like parts involved and how you made the connection to your panel?
Thanks,
Paul from Tucson
An inverter simply plugged into an outlet runs the risk of putting lethal voltages out on the grid when the utility guys expects no power.
Just remember AC can go both directions through transformers, so an automatic disconnect of some sort is a good idea. Might even save a fine or three; or occassionally a life.
Linemen have been killed by folk doing non-standard things in homes, like adding power sources that energize the grid when there's a power outage. Something plugged in to an outlet seems like one too many corners cut. As for my experience? I designed my first power supply and 500WS landing strobe in 1972, even helped Bonneville Power Administration design some power test gear. I've even had the experience of being kicked across the room while working on gear poorly designed by someone who had a lot more experience than me. So experience isn't always what you expect; and bad ideas are still bad ideas.
In Phil's defense, he may have meant an inlet socket, not an outlet; he may even have a full grid rated inverter complete with disconnect. But those words weren't used, so there is room for confusion and concern.
You're right Phil, I didn't ask.
Quoting a source: According to [OSHA]….60 to 100 linemen annually suffer “devastating” injuries that leave them permanently crippled, missing limbs, or severely burned. And that’s not counting the workers injured at publicly owned utilities such as those run by cities. Those companies, which make up as much as one-third of the U.S. utility industry, don’t have to report injuries to OSHA.
I also was quoted by Solarcity on my new (read: highly efficient) home. Over the 20 year span, my projected savings were only $5800 or roughly $24 per month. Not to mention I'd have to lease the system for 20 years, potentially risk the buyer of my home not wanting it or not qualifying for the lease takeover, and the fact that Solarcity is making out like bandits by keeping the tax incentive and whatever the overage is from my power production (because they fix the cost). The numbers didn't add up for me.
I did plant a few trees last summer, but they're on my fence line. My worst wall for exposure is 2 stories tall, and faces SSE, so gets early morning to mid afternoon summer sun. 2/3 of that wall is adjacent to concrete pad, with no chance for shade. I had some kind of cat=claw vine thingy that the PO let grow to cover the wall, but honestly the damage to the stucco, and intrusion into the attic, and harbor for birds, bugs, lizards and scorpions wasn't worth it. I'm sure it helped a little, but not worth the hassle....A shade tree or three was a fair way to help cut cooling costs. R-19 walls work better with the exterior shaded surface at 100 degrees than sunlit 150+ degrees (100-80=20 degrees where 150-80=70 degree diff); and it's even more effective if you have R-13 2x4 walls. Even looked at trellises and ivy... and a $100 tree is pretty cheap compared to a $20,000 panel array.
