My '83 FJ60 has been running hotter than I think it should...still in the operating range and often around halfway, but when driving highway speeds for any period of time the temp needle starts to creep up into the top third of the white zone. Anywhere in the white zone may technically be "normal" but I'm expecting to see the needle at halfway or slightly below.
The PO replaced the smog pump with an old alternator, consequently the belt used for the water pump is thinner and has shorter, less aggressive "teeth" than the stock belt. I noticed while replacing the fan clutch awhile back that when I put a wrench on the fan to loosen the bolts I could spin the water pump pulley under the belt, even when tensioned.
I decided this weekend was time for my cooling system overhaul and put this nagging issue to bed.
I pulled the radiator and had it pressure tested and cleaned. The guy said there wasn't any significant sediment or junk inside - not enough to make it run hot. I replaced the water pump, just because. I installed one of Jim C's idler pulleys as well as a proper belt (the pulley doesn't slip while I tighten the fan now). I installed a water temp gauge (sender in the upper radiator hose) in addition to having the stock gauge. I replaced the thermostat and all hoses a few months ago as well as the fan clutch. Put in new coolant and got some good burps - good heat at the front and rear heaters.
Imagine my surprise when I find the stock temp gauge climbing right back up to the top 1/3rd of the temp gauge - even while idling, which it didn't do before. All the while, my new water temp gauge is telling me that it's at 190-195 steady.
I can't imagine that the truck would run hotter now than it did before, but I'm also leery knowing that the new temp sender in the upper radiator hose can get different temps than the sender at the back of the head. Even with the difference in locations I can't imagine the difference in actual temps would be that large. I guess the stock sender system or gauge itself could be faulty due to age...don't know which indicator to put my trust in.
Also - probably because I'm paranoid now - but I swear the valves or pushrods are louder than they were before I did the weekend job. I didn't touch anything other than those items I mentioned so I find myself overthinking this....could the resonance of the block or head be different due to coolant not circulating properly or am I crazy..what could cause this, besides my imagination?
Thoughts appreciated.
