smells like gas in my rad :(
Discussion in '60-Series Wagons' started by FJ60LG-K4, Sep 2, 2008.
  1. FJ60LG-K4
    FJ60LG-K4
    24
    Aug 12, 2008
    Toronto
    There s also brown(oil)
    could it just be that it ran real rich or am i looking @ another pricier issue.
    Should I flush and see what happens,drive around with water for a bit?
    thanks
    MA
  2. Wile E Coyote
    Wile E Coyote Out in the streets, they call it murder! SILVER Star
    3,176
    Media:
    9
    40
    Sep 20, 2005
    Western AZ
    I'd look for other signs that the head gasket took a dump, or even the oil cooler is bad.
  3. PhilC64
    PhilC64
    2,576
    Media:
    4
    3
    Apr 1, 2007
    Peoples Socialist Republic of Chicago
    X2^ Chocolate Milk looking anti-freeze means oil got in there somehow. Do a compression check first and see where it leads you.
  4. Matt60
    Matt60 KiSS of Death
    662
    Media:
    22
    Aug 24, 2005
    the oil on the stick is brown? radiator smells like gas. does it shoot water out the filler neck when the cap is off and running?
    pull the head-
    oh and good luck
    matt
  5. sdbrassfield
    sdbrassfield
    662
    3
    Oct 12, 2005
    Flatwater, NC
    Oil Cooler x2...Bypass it temporarily
  6. wagon4wd
    wagon4wd
    270
    93
    Nov 2, 2007
    Gold Country, CA
    The fuel smell in the radiator concerns me and makes me think that it might be more than the oil cooler, and be more like a head gasket or cracked head. But certainly do the easy troubleshooting first.
  7. cruiser88
    cruiser88
    11,876
    Media:
    3
    31
    Feb 21, 2006
    Medford Oregon
    I also think the fuel pump is leaking gas into the crankcase if it is not then your rig is running really rich. ...but yep its time to do a compression check.
  8. mrlocksmith
    mrlocksmith
    422
    Media:
    9
    2
    Sep 9, 2007
    Vegas Baby !
    Although the gas smell in the Rad pretty much nails it, there is a kit you can buy from Napa to confirm the problem:
    Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
    Then you could do a "Leak Down" test, somewhat like a combustiuon test but gives you a much better picture of what is going on in the motor as you can monitor how much air pressure escapes from a cylinder and more importantly in your case... find out where the air goes... If you get bubbles in the rad as I suspect then you will have to address it.
    http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/index.html
    Mark
  9. wagon4wd
    wagon4wd
    270
    93
    Nov 2, 2007
    Gold Country, CA
    Duh, forgot some of these weren't injected and had a fuel pump attached to the block. Had that problem on an old cherokee a while back. :rolleyes:
    Like everyone else says, though, it's time for at least a compression check. While it's possible a few things could fail at the same time, it's a lot more likely that it's just one thing causing all the symptoms.
  10. FJ60LG-K4
    FJ60LG-K4
    24
    Aug 12, 2008
    Toronto
    environment + procedure
    good one
    do not have that tool NEED it :)
    PRIOR to starting this project:
    `search...read
    ` located some canisters. To bleed/clean the fj60(lot's of liters/gallons of pollute)
    read /searched
  11. FJ60LG-K4
    FJ60LG-K4
    24
    Aug 12, 2008
    Toronto
    running RICK it was. Carb ,air intake... everything THE smell from the exhaust
    Compression
    1 @125
    2 @ 130
    I stop compression testing. Get depressed quick
    no matter,LC ran b4,senses got invovled oil,gaz,green or yellow red but it RAN
    Really needed canisters to dump the oil,gaz,green or yellow red drainage
    +++ decided to be a wire guy... groundin... to be followed
    PS WOW thanks for the tips and postings! and PICS:bounce:
  12. FJ60LG-K4
    FJ60LG-K4
    24
    Aug 12, 2008
    Toronto
    oil inside engine, actually dipstick was pretty good,but PO could of changed it a month earlier
    Didn't boil over No
    I changed(garage) when I got certification done. Along with ALL fluids besides :eek: rad.
    I ll double verfy if THEY did the job,paid cash to save 15% rear,transfer case,grease every greaseable'S.
    Then I get more familliar with my FJ60
    No Steam out of muffler
    FJ60 2F I ll attempt pulling(heads+gaskets/boats:)) crammin(stuff),stompin(anyt'in),pushin(more)climbin(higher) now to get it started! no more CLIKKs please
    you mean
    "Leak Down" test,
    How to do Cylinder Leak Down Testing- Car Craft Magazine
    Mark[/QUOTE]
  13. Bahndo111
    Bahndo111
    229
    Sep 27, 2005
    Hood River, OR
    [/QUOTE]
    uh..... huh?
  14. RockDoc
    RockDoc my bad habit SILVER Star
    6,691
    Media:
    3
    331
    Jun 3, 2007
    SW MB, Ca
    I think Tntoyota/Hilux has a Canadian cousin.
  15. Wile E Coyote
    3,176
    Media:
    9
    40
    Sep 20, 2005
    Western AZ
    :doh:
    FJ60LG-K4, slow down bud. We're losing you. Personally, I don't know whether you're asking for more help, or just sharing your inner dialog with us? Good luck with your project, either way.:steer:
