sm420 stuff
Discussion in '40- & 55-Series Tech' started by tennfj40, Jan 9, 2003.
  1. tennfj40
    tennfj40
    28
    Apr 29, 2002
    I know I am bugging everyone with questions today, but was also considering sm420 conversion, was looking at tech section and saw the install, do you not have to change the ouput shaft on the sm420 so it will mate with the4 speed tc, or is that $200 adapter plate kit all I need?
  2. woody
    woody Internet Fireman Staff Member
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    the SM420 output is 10 spline and matches the 73-older t-cases. AFAIK, there is NO adapter from the SM420 to the fine-spline 74-newer t-cases. (AA might have one, but it would be a LONG adapter and not just the plate)
    The 73-older t-cases are 16% lower in the low range and still 1:1, so you do get a bit better crawl.
    IMO, finding a 73-older t-case will be cheaper than replacing a mainshaft in the SM420 (if one is even available) and likely cheaper than the AA stuff (if that's even available)
    (am I even here today....d'oh!!)
  3. Mace
    Mace rock scientist.. Staff Member s-Moderator
    20,641
    1,077
    Feb 17, 2002
    Las Vegas
    AA does make the adapter but it is like $400
    Find a plate and case (sell the 4 speed to finance the new case.. )
    Or get a really old case (the brittle ones) for next to nothing because no one wants them, and stuff the gears in to the 4 speed case :)
    Much stronger..
    Oh yeah, then get a plate adapter ;)
  4. Planet_X
    Planet_X
    190
    Feb 8, 2002
    sm-420 mated to 4-speed transfer case w/plate style adapter. Key 10spline input gear w/4-speed teeth count.
    [​IMG]
    [​IMG]
    [​IMG]
