how long does it take for plates to destroy the brackets? I've yet to see any evidence of that.
I suppose when your truck ends up like Onur's then some things just happen. I'm trying to imagine the plates on mine failing worse than s***ty bushings. imho.how long does it take for plates to destroy the brackets? I've yet to see any evidence of that.
Maf drop brackets would be the right way.
Not if you want to run bolt on Sliders.Maf drop brackets would be the right way.
White knuckle slidersNot if you want to run bolt on Sliders.
After running Slee plates for a few years and rising to 6” lift with zero castor angle, I dropped my rig an inch and bought Delta VS arms. Much better.Can slee caster correction plates and caster correction bushings be used at same time? I can’t visualize how this would help since plates are fixed at the arm and axle mount. I currently have slee plates, about 4-5” of lift and caster is 1.4° left, 1.9° right. I have a question out to slee right now.
I’m leaning that way, of buying delta arms. I emailed with Doug at Delta today and he was very helpful and walked me through a recommendation. Exploring the option of making these OEM arms work better or just buying Delta arms. I’m going to change to the 3” pan hard lift bracket and see what that does and then address arms.After running Slee plates for a few years and rising to 6” lift with zero castor angle, I dropped my rig an inch and bought Delta VS arms. Much better.
Correction bushings with plates will have a double affect on castor I would think but why bother? Get the Delta arms and be done.
The wobble is probably the tires. Don’t know what you are running but I’m on 37” trXus radial mud terrains. The go trough cycles. At times they will lose lateral balance at about the same speed you said. Rotating or just driving longer seems to correct it.I’m leaning that way, of buying delta arms. I emailed with Doug at Delta today and he was very helpful and walked me through a recommendation. Exploring the option of making these OEM arms work better or just buying Delta arms. I’m going to change to the 3” pan hard lift bracket and see what that does and then address arms.
The issue I’m having is a developing wobble around 50mph and slight turns.
I think the tires aren’t helping, 37” Mickey Thompson MTZ. It seems like I can feel the oscillation start in the tires and then it progresses and I can straighten up and drive out of it to a different speed.The wobble is probably the tires. Don’t know what you are running but I’m on 37” trXus radial mud terrains. The go trough cycles. At times they will lose lateral balance at about the same speed you said. Rotating or just driving longer seems to correct it.
