Shimmy at 50mph
Discussion in '40- & 55-Series Tech' started by jscottclark_77FJ40, Aug 5, 2003.
  1. jscottclark_77FJ40
    jscottclark_77FJ40
    14
    Apr 12, 2002
    I've been messing with a front end shimmy on my '77 FJ-40 for some time now. It has 4" SUA lift springs, JTO 2.25" anti-invert shackles, and 35" MT Radial Claws on 10" Fake beadlock rims. All bolts are tight and torqued. Tie rod ends are good. I've added a new stock stabilizer, plus an aftermarket Rancho. I have even rebuilt the center arm. I need to recheck is tire balance - my concern is that they are not dynamically in balance, due to the fake beadlock outer rim, or the ties are out of round. The shimmy starts at about 50-55mph - never gets into the "death wobble" though. Could it be as simple as dynamic balance? My dad thinks my 4 degree shims aren't enough, and the caster is off, but it drives straight and steers correctly in corners. The driver's front wheel is leaking something, and it's bearings may be a little worn. It wasn't as noticeable with the hardtop and doors on, but I run it now without. Anyone?
  2. 78 One owner
    78 One owner
    337
    Jul 20, 2003
    Veyo, Utah (near St.George)
    The tires or the wheels or any combination thereof could be the problem. I had cheapo rims that got tweaked at Moab. I didn't know what the problem was till moved the mounted tires to differentwheel locations. One way wasw even worse,any location was bad. To prove that I put my old rusty white spokes back on,wore out BFG M/Ts and all. It rode fine after that. Bye,bye new wheel, and tires. I traded them to a guy with a Trailer Queen for some tires for my '78 Commander motor home. We were both happy. :D
  3. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Check out the thread on "35s front end shimmy started by sambudo. I bumped it up for you.
