Shackle Reversal...reversal.
Discussion in '40- & 55-Series Tech' started by BlueCruiser84, Jan 25, 2012.
  1. BlueCruiser84
    BlueCruiser84 SILVER Star
    2,253
    329
    Nov 1, 2004
    Staunton, VA
    I have a PO installed shackle reversal with the front spring mount right on the frame. The mount is a factory spring mount that was cut off its original location and rewelded on the front.
    My question is are there any companies that make a shackle that would fit inside the spring hanger mount? Similar to a Cherokee rear shackle. <--LINK (Link doesn't work - See picture Fast Eddy posted below)
    I am sprung over with fj60 power steering so the spring hits the drag link - I know there are other things I can do to get around this, but honestly i would like to get the shackle back out front without tons of work and I thought something like this might be a viable option.
    Thoughts? Reasons not to?
  2. bikersmurf
    bikersmurf
    6,712
    Media:
    59
    397
    Apr 2, 2008
    Victoria, BC
    Link wouldn't work for me.
    Why do you want to reverse the reversal?
    I think it would be simplest to throw a shock mount back up front and use stockish shackles.
  3. Fast Eddy
    Fast Eddy SILVER Star
    14,138
    1,529
    Apr 5, 2006
    Morgan Hill, CA
    If you really wanted to do it you could make the jeep ones work. If you're going to have to weld the other end, you might as well do it right though.
    [​IMG]
  4. BlueCruiser84
    2,253
    329
    Nov 1, 2004
    Staunton, VA
    I don't really care either way on the shackle reversal. The shackle reversal makes clearance for the fj60 steering box setup a bit tight. I thought if there were a shackle available I would go that route and save myself some headache. Just poking around really.
    The shackle reversal is also set up so the front of the spring is higher than the back of the spring - factory hanger welded to frame and shackle frenched into frame. I suppose I could cut the hanger off and weld in a spacer. That would give me clearance and a better spring angle.
  5. bikersmurf
    bikersmurf
    6,712
    Media:
    59
    397
    Apr 2, 2008
    Victoria, BC
    Or, weld a piece of pipe through the frame on the rear, and reposition the top of the shackle. You could also redrill the centerbolt holes to fix the steering clearance issues.
  6. BlueCruiser84
    2,253
    329
    Nov 1, 2004
    Staunton, VA
    Shackle is already through the frame. The clearance issue is up and down clearance between the top of the leafspring and bottom side of the drag link. I need to install my flat pitman arm but that will involve notching the frame. Not a big deal, but if I could do something that doesn't involve me cutting my frame I would rather go that route.
  7. BlueCruiser84
    2,253
    329
    Nov 1, 2004
    Staunton, VA
    Does anyone other than Sky Maufacturing make a 1" drop pitman arm? The ones from Sky are ABSURDLY expensive. Can pitman arms be bent?
  8. Lil'John
    Lil'John SILVER Star
    4,125
    256
    Mar 24, 2006
    Nor Cal in the garage with a Cruiser
    If you want to reverse it, the "easy" way to do it would be a through the frame shackle in the front.
    I went that method on my old FJ40 when I reversed a shackle reversal.
    On my FJ55, I intend to do the same modification: through the frame shackle mount at the front frame horn and leave the fixed end hanger alone after reinforcing it.
