SEM Tintable Liner
Discussion in '40- & 55-Series Tech' started by citabria, Aug 13, 2003.
  1. citabria
    citabria
    26
    Mar 30, 2003
    Anyone use this spray on liner?
    SEM sells it with a Schutz gun but the guy at the paint store tells me I need a "good" gun to spray it.
    FJ-40 1975
    Rear Brakes Disc'ed, Fronts ready to do mini swap
    Body just back from Baking/blasting
    Frame off, down to metal and POR-15ed
  2. Sparky_Mark
    Sparky_Mark
    191
    Mar 13, 2003
    Raleign / Durham, NC
    Citabria,
    After much research I used SEM's basic Truck Bed Liner kit (black). I was using it on new steel (I had to fab up a new floor pan for my FJ40). Here are a few of the basic steps that I had gone through...
    Since I was using new steel, it had a bluish coating called "mill scale" - it's an oxide that is inherent in the hot roll process. It MUST be removed before applying any coatings.
    Prep - I etched the mill scale off using a product that has a high concentration of phosphoric acid (protective clothing, safety glasses, and respirator). You can sand blast the stuff off as well (recommend a pressurized blaster).
    Primer - Since the SEM product is a urethane, I used a 2K epoxy primer on the bare metal to ensure good mechanical and chemical adhesion of the truck bed liner coating.
    After the primer was down, the recoat window was between 1 hr and 4 days (after that you have to scuff up the surface. You loose the chemical adhesion if you don't reprime).
    Putting the truck bed liner coating on - I used a body shutz gun (really just a siphon feed air gun) that cost me about $25. You can find them at Harbor Freight cheaper. In my opinion, you don't need a high performance gun since the coating will have a texture to it (it's really thick which is why you have to use an undercoating gun to apply it). The texture will depend on the pressure at the gun - use a regulator to control it.
    I put 2 coats on with the kit I used and have been very happy with the results. I took some pics, so I'll post them tomorrow. The kit cost me about $130, so I did it all for less than $200 (considering that I use a really expensive primer).
    Other similar 2K urethane products can be found from Morton and Gator Guard.
    Good luck
