secondary carb diaphragm
Discussion in '60-Series Wagons' started by beaufort-fj60, Feb 18, 2008.
  1. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    I'm changing out the secondary carb diaphragm. Sor has one for $45, napa $14, and all kinds of prices in-between those. Has anyone replaced the rubber in the old diaphragm? That couldn't be more that five cents worth of rubber.
  2. rchalmers3
    rchalmers3
    1,540
    2
    Jun 29, 2007
    Playas de Nosara, Nicoya Peninsula, Costa Rica
    Great photos!
    I know there are rebuilders who repair rather than replace the assemblies. But they usually are working on obsolete stuff. $14 from Napa seems like a great value. While it's still available that seems like a fair exchange. To me.
    Rick
  3. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    $14 is cheap, I'll probably go with the Napa one. Just wondering if any other cheap-skates out there tried to rebuild it. :D
  4. FJ40Jim
    FJ40Jim The Cruiser Whisperer
    9,102
    819
    Sep 26, 2003
    Lancaster, Ohio, USA
    $14 is cheap.
    Amusing repairs:
    Seen some diaphragms that were skinned w/ a layer of RTV snot.
    Seen some Holley diaphragms w/ Aisan link brazed on to the chopped holley link.
  5. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    :whoops:$21.74 for part/tax/shipping.. Only problem with the Napa part is; the guy at the store said no stores have the part and it is ordered from the "factory". That either means I'm not going to get it or it will take awhile. wild guess
    are most of the diaphragms you see in rebuilds old, torn, and cracked? The one in the above pics sounds like a piece of paper its so dried out.
  6. Willius
    Willius
    101
    1
    Oct 23, 2007
    West Seattle, WA
    Click Here: Carburetors
    I replaced my diaphragm with the one that came in this kit. If you haven't done a tune recently, do one, otherwise it'd be good to have some spare tune parts around. Mine arrived in about a week.
  7. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    CCOT is a little to overpriced for me...
  8. FJ40Jim
    9,102
    819
    Sep 26, 2003
    Yes, they are usually bad after ~20 years.
    I've got the diaphragm in stock for about NAPA price. Email me for info.
  9. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    I ordered the Napa one a few hours ago. :doh:
  10. Gargoyle
    Gargoyle
    3
    Feb 16, 2008
    I have replaced the ribber in the diaphragm on several occasions and have learned the hard way. Make sure not to tighten the screws to tight - this will cause warping and leaking. Also placing the bottom of the diaphragm over the rod and then push the rod up so that the spring is compressed before tightening the screws will prevent the rubber from being stretched or wrinkled causing leaks. I have found that even the tiniest leak will render the diaphragm useless. Frankly, I would gladly pay $15- $20 for a new leak free diaphragm. I did not know they were for sale - Thanks!!
    -Gargoyle
  11. Marc311
    Marc311
    947
    2
    Aug 7, 2006
    Northern Virginia
    So, what is the function of the carb diaphragm?
  12. FJ40Jim
    9,102
    819
    Sep 26, 2003
    Marc, the secondary diaphragm has vacuum applied to one side of it by passages in the carb. The vacuum overcomes a closer spring and actually pulls open the second barrel on the carb.
    When the rubber is cracked and leaky, vacuum cannot build up behind it, so the secondary never opens.
    Sadly, this $14 failure has probably lead to several V8 swaps. (nothing wrong w/ a V8, just an extreme solution for a $14 problem).
  13. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    Can you put in a "weaker" closer spring to tap into the secondary a little earlier?
  14. FJ40Jim
    9,102
    819
    Sep 26, 2003
    Yes. There are different Aisan springs available. Plus the Holley springs will fit, though they look a little different.
  15. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    is this the spring inside of the diaphragm? .. never mind... I got it.
    Vac pulls, overcomes the spring (compresses it inside the diaphragm), rod connected to diaphragm pulls on the end of the secondary butterfly rod, rod turns, secondary opens.
  16. kranky al
    kranky al
    3
    Feb 20, 2008
    how hard is it to rebuild a carb - there is a guy wrecking a 60 and i was thinking of buying his old carb and rebuilding it - im no mechanic - but i like playing around with fiddly s*** and thought i could rebuild his and when finished swap it for my old had it carb - and worst comes to worst - if i cant put it back together - just hand it over to competent authority
    thoughts?
  17. CruisinFJ60
    CruisinFJ60
    6,148
    Media:
    219
    24
    Oct 19, 2006
    Ft. Worthless, TEXAS!
    its easy I re-built mine in the same day that included taking it off and re-installing it all back on the truck. just a buncha little parts but the re-build kit should come with a picture w/ numbers to show u where everything goes in case you forget.
  18. JLH911
    JLH911
    2,401
    4
    Sep 2, 2007
    So. Cal
    Could/Would this cause rough idle?
  19. beaufort-fj60
    beaufort-fj60
    4,508
    Media:
    10
    8
    Feb 5, 2005
    Like cruisinfj60 said, the carb rebuild kit comes with a diagram. The factory service manual has a very nice write up on the whole carb rebuild.
  20. FJ40Jim
    9,102
    819
    Sep 26, 2003
    No, not in the least. The entire sec.diaphragm assembly could be left off the carb and it would start & idle fine.
