Sealer for Differential cover gasket?
Discussion in '40- & 55-Series Tech' started by Soul_Man, Jan 24, 2006.
  1. Soul_Man
    Soul_Man
    318
    Apr 17, 2003
    Jacksonville, FL
    Just got my axle all rebuilt with ARB's installed :grinpimp:
    When putting the cover on: I have the cork gasket, but what is the stuff that you use to seal it? Do you put it on both sides of the gasket? Should I put the gasket on dry (no sealer)???
    I really don't want it to leak :D
    (I did a search, and look in the tech articles, but couldn't find the info)
  2. Muspos
    Muspos
    140
    Sep 20, 2005
    Sublimity, OR
    My 2 Cents!
    I clean both surfaces extremely well and place a light film of Ultra Black RTV on both surfaces, let it dry five to ten minutes then put it together with the cork gasket and very lightly start the bolts. I let it dry a 10-15 min and then torque the bolts to specs. I have never had any thing leak, knock on wood!
  3. projektdotnet
    projektdotnet
    1,840
    Sep 26, 2005
    Port Orchard, WA
    1. gasket sinch, yes it is the actual name of the product, both surfaces that will join...when starting to become tacky apply gasket to diff plate properly aligned and let dry together.
    2. Repeat for attatching plate to housing...torque and let dry. dont forget to check for leaks before driving.
    :cheers: almost how muspos does it but just with a different timing and different product
  4. wesintl
    wesintl
    4,511
    15
    Mar 14, 2003
    Highlands "F'n" Ranch
    Put the cork on dry. I've never had a cork diff gasket leak.
  5. VTFJ40
    VTFJ40
    632
    Jun 16, 2004
    Northern Vermont
    Agree with this.
  6. Cammy
    Cammy
    237
    Apr 29, 2005
    In my experience cork gaskets tend to dry out during storage (post production) and are not as plyable. If I have to use a cork gasket I smear a little vasaline on the gasket before assembly. The vasaline will soften the gasket and makes it easier to remove if you ever have to take the cover off. Works great on valve cover gaskets too.
    Just be carefull not to get the vasaline all over your hands, your wife will think you were wrenchin something else.:D
  7. e-man
    e-man
    143
    1
    Mar 28, 2005
    Fort Worth
    I made my gasket with a pair of scissors and some blue gasket material from O'reilly. Put a little RTV bolted it on and it has been leak free.
  8. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    19,932
    Media:
    17
    185
    Oct 1, 2003
    MN
    X3.
    As long as the sealing surfaces are clean and dry, you will be good to go.
    Good luck!
    -Steve
  9. ranger
    ranger
    1,152
    1
    Jan 18, 2003
    Idaho
    X4 Cork is best.
    If you use RTV and it comes time to service, do maint, or whatever on the diff, that stuff is a PITA to get off.
  10. nuclearlemon
    nuclearlemon not an addict Moderator
    15,473
    Media:
    87
    357
    Jan 30, 2003
    meh-ico, colorado
    i hit mine with a little hi tack so they come off easier.
  11. honk
    honk SILVER Star
    3,300
    Media:
    8
    270
    Nov 14, 2004
    PNW
    I like a little RTV on the cover to stick the gasket and make sure it doesn't flop, slide, or otherwise somehow get a little misaligned, but it probably isn't necessary.
  12. Soul_Man
    Soul_Man
    318
    Apr 17, 2003
    Jacksonville, FL
    What torque for the nuts???
    I put a little black RTV. Was nervous about putting it totally dry :eek:
    Can't find torque specs in my Haynes manual or the Factory manual :confused: I generic guide I have says for 10mm bolts/14mm nuts to use 36 N-m.
    I did them finger tight, then a bit tighter (and was going to let it sit 10-15 for the RTV to set up) but it seems like the cork is trying to squeeze out if I go any tighter :eek:
    Should I let it sit and then go to 36 N-m?
  13. Poser
    19,932
    Media:
    17
    185
    Oct 1, 2003
    MN
    I would let it set up for a couple hours and then tighten them up....because you did not want to install the gasket dry. ;)
    DO NOT put oil in until AFTER everything it sealed and tight....or you will be doing it again. :)
    Good luck!
    -Steve
  14. HawkDriver
    HawkDriver
    3,218
    Media:
    64
    8
    Feb 1, 2002
    No. Ogden, Utah
    I prefer to use a dry cork on tins or diff covers. Unless I forsee a problem area, then I might add a touch of RTV. On 3rd members I just use blue RTV and install it wet, don't let that shit harden and create an uneven surface.
    My .02
  15. rusmannx
    rusmannx
    1,136
    3
    Feb 9, 2002
    HIT IT!
    i don't even have a gasket on mine, just black rtv, no leaks in about 2 years.
  16. Soul_Man
    Soul_Man
    318
    Apr 17, 2003
    Jacksonville, FL
    Well, I got it tight to just where the gasket wanted to squirt out. I let it sit like that overnight and this moring I was able to torque it with no problems.
    Funny, when the gasket started to squirt out I thought: no wonder a lot of the guys said to put it on dry...:cheers:
