Seafoam or Berryman's B-12?
Discussion in '60-Series Wagons' started by dogboy2, Dec 9, 2004.
  1. dogboy2
    dogboy2
    996
    5
    Jul 8, 2004
    Portland, OR
    Seafoam or Berryman's? I'm thinking I might need to clean out the combustion chamber/valve train on the '60.....do these products actually work? Any damage to seals/gaskets/etc...? Negatives? Positives?
    Always have been hesitant to put any aftermarket additives into the system so those with firsthand experience please pipe up before I go and do something I might later regret....:doh:
    Thanks,
    -dogboy- '87 FJ60
  2. pasnkhunter
    pasnkhunter
    37
    Aug 14, 2004
    Bellwood,Pa.
    Have had good results with Berrymans, great stuff.
  3. Doc
    Doc
    5,845
    106
    Apr 26, 2004
    Utah
    Does Seafoam work? Hell yeah!
    The first time I treated my 87 FJ60 with Seafoam was in a parking lot of an auto parts store, guys were stopping to ask if I needed a ride home, because the black smoke coming out of the tail pipe was making them think my motor blew! It really does the trick when it comes to cleaning out carbon deposits- two thumbs up!
  4. Benji
    Benji
    1,087
    Feb 12, 2004
    North Texas
    Be careful, I would use Berryman's for the fuel tank and Seafoam for the carb system. Yeah, they can do a number on your gaskets. Also be careful as they can loosen up deposits that will haunt you in the long run. Unless you really think you need it, then use it; otherwise don't.
    Hell, I use them all, but I am prolly wasting my money.
  5. wngrog
    wngrog SILVER Star
    17,879
    4,660
    Feb 10, 2002
    Canton, Mississippi
  6. MR.FJ60
    MR.FJ60
    565
    Feb 4, 2004
    Westminster,CO
    Could someone elavorate a little more on these two products? Are they available at my local autozone? How are they used? Thanks in advance guy's.
  7. devo
    devo
    838
    2
    Nov 3, 2002
    denver
    No body is mentioning 44K? (K44?)
    devo
  8. swank60
    swank60
    1,493
    217
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Yes - and the uses are all on the side of the can...
    which leads to:
    As far as which is better, I'd say it depends. They are a little different. Seafoam into the manifold is great for clearing carbon, and in the crankcase it's helped mine idle smoother and more quietly. I've put both in the tank and never noticed a difference.
    I like B12 for cleaning though. I keep spray cans and the open top cans in the garage at all times. I've run B12 through the oil just before an oil change, too. Seems to do an okay job cleaning things out, but I haven't seen any huge benefits from using it...(but again, it's great for parts cleaning. I don't use anything else if I can help it.)
  9. MR.FJ60
    MR.FJ60
    565
    Feb 4, 2004
    Westminster,CO
    Thanks a bunch swank.
  10. jeepgod
    jeepgod
    480
    Sep 19, 2009
    North Las Vegas, NV
    How do you seafoam the the motor without putting in the gas tank
  11. Doc
    Doc
    5,845
    106
    Apr 26, 2004
    Utah
    Pull one of the vacuum lines off of your brake booster.
  12. sl33py
    sl33py
    2,160
    5
    Jan 8, 2004
    Emerald City
    i like Seafoam, and think it works great - but haven't tried B12 before.
    I usually pour down the carb while keeping the RPM's up, then let it bogg and die so seafoam can soak some parts for 10-15 min, then fire back up and go!
    I've heard about fouling issues and such, so typically do it just before i change plugs and oil. Also usually put the other half of the can into the gas and/or oil.
    Not "magic in a bottle" but works very well IMO.
    GL!
  13. xulcuz
    xulcuz
    87
    Jan 4, 2009
    Holland, MI
    Had great results in the cruiser with seafoam, would for sure recommend it.
  14. bigDcruiser
    bigDcruiser
    335
    Oct 28, 2007
    Dallas till i get to Austin
    i run b12 through my fuel every so often. not sure how much it helps since i still have to use starter fluid almost every time i get in the truck. i've also done the seafoam treatment which worked wonders on helping to identify all of my exhaust leaks. i had smoke spilling out of cracks and crevices from the manifold to the tail pipe.
  15. julstirn
    julstirn
    1,774
    4
    Jun 9, 2008
    Augusta Maine
    as i understand it you put some seafoam in the gas tank in with the oil and in your carb or throttle body, and it is smart to do it during a tune up cause i believe you are supposed to change plugs at the same time. It loosens alot of gunk up in there which is why you change oil and plugs and such at the time you do it. I have heard wonders though. Look on youtube , theres some videos.
  16. ntsqd
    ntsqd technerd
    4,980
    64
    Apr 26, 2007
    Upper So. CA
    I used some Seafoam on my 160k miles TBI Sub. Put the whole can in the fuel tank and then filled it to it's full 40 gal. capacity. Mileage from that tank sucked, but the smoothness & drivability did slightly improve afterwards.
  17. cando john
    cando john
    134
    Sep 14, 2006
    philadelphia
  18. Cruzerman
    Cruzerman
    1,556
    95
    Apr 23, 2005
    Oregon
    Pouring Seafoam straight into the carb is worth it just for the smoke!
  19. Mark W
    Mark W
    6,177
    57
    Jan 7, 2005
    The Greatland
    Guys... WATER in the intake will clean the combustion chambers. That trick is older than anyone on this board. Not a damn thing special about Seafoam there.
    Please elaborate on how Seafoam... or anything... added to the oil in the crankcase will improve how the engine runs. With supportable arguments, based on some sort of science or at least demonstrable repeatable facts.
    Mark...
  20. specialk396
    specialk396
    458
    Aug 4, 2009
    Waynesboro, Va
    hasn't mythbusters done something on this?
