Official hijack: Scott, when is 2015 tech day?
Has a date been set & I missed it?
Sadly I'm not very observant!
Not positive so draw your own conclusions....but
It sounds like the 1-2 shift fork may be busted. Without synchros downshifting into first would likely sound quite "bad". With the ring broken around the fork, it will not always go all the way into first. AFIK the 151s have the same fork design, and act like you describe when broken.
The fork is aluminum, but the chunks are way too big to be floating around a trans for long.
*****Edit
Payment plans are acceptable if you are planning/need to build before spring.
I think that's wishful thinking. An input bearing would make noise in all gears. I think the synchro is probably a good bet now. Trans has to come out. Look at stuff as you disassemble. No point in speculating.
I say 6.0 as well & also there's the whole I agree with whatever the one true Ginger says, I'm a sheep, but I'm Gingers sheep damn it!
And what a compliant sheep ewe are.
Yea I'm leaning twords that or he syncro, I was talking with one of our equipment engineeers at work and he was talking about the syncro, he said he has seen where this has been a symptom of a bad one. The plan is to get a billet shift fork from marlin regardless and toss a rebuild kit at it, if I have the trans apart, I might as well refresh it. I'll buy the axles one way or another!!
Scott I'll be at tech day for sure!! I have a trans Jack if one is needed.
You shouldn't lose core money because your trans was too worn out....
Funny. Your trans felt great compared to the one in the 4 runner I sold Joe!!
You didn't drive it after it started popping out of first and venting its fluid all over the place. It sounded like a cement mixer by the time o was yanking it out.
