SBC guys.....what are my exhaust options?
Discussion in '40- & 55-Series Tech' started by In2cruisers, Feb 16, 2010.
  1. In2cruisers
    In2cruisers
    5,353
    26
    Aug 13, 2004
    Normandy Park Wa. ........now in San Diego Ca.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Im pretty tight...The motor is centered in the frame....and would like to keep it there.
    Are there any manifolds that are tighter against the block than ramshorns...
    Dont know if I can use a rear dump... will it conflict with clutch slave?
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    19,931
    Media:
    17
    185
    Oct 1, 2003
    MN
    Sanderson make some really nice stuff, but it also cost real money....
    :meh:
  3. dgangle
    dgangle total rice SILVER Star
    4,000
    4
    Nov 24, 2004
    Heart of Dixie
  4. fieldsken1
    fieldsken1
    2,571
    Media:
    108
    24
    Nov 6, 2007
    in my little world
    how about block huggers then 2.5 inch duals all the way back comming out right behind the rear wheels. if you go straight out the back you will get alot of exhaust fumes inside so do come out the side
  5. In2cruisers
    In2cruisers
    5,353
    26
    Aug 13, 2004
    Yes those will work I think..do you have a set? What do I use for referance...yr...model...when looking for them?
    Also.....#1 might work, #2 looks like it drops on-top of the dipstick and or spark plug
  6. dgangle
    4,000
    4
    Nov 24, 2004
    Heart of Dixie
    cast manifolds are your best long-term/best benefit/lowest cost & hassle solution plus they are made to clear these things. not sure on the exact application but boneyard scrounging may reveal sources as well as provide ideas. lots of good ideas and pix from Chevy Exhaust Manifold at 1AAuto.com look for anything Chevy 70-mid 80's car or truck. Their pix are good references.
    I have thrown many of these away from donor engines before I knew they were applicable. Much more common than ramshorns.
  7. DomSmith
    DomSmith SILVER Star
    2,187
    Media:
    1
    86
    Nov 16, 2004
    San Diego, CA (South O)
    Be sure to get a set w/o air injector holes or you'll be stuck with plugs.
  8. 2fpower
    2fpower
    5,712
    872
    Sep 5, 2007
    lenexa, ks
    Not to pose a stupid question, but would it be cheaper and better in the long run to move the saginaw in the front and not mess with the exhaust?
  9. Plowboy
    Plowboy
    798
    Apr 21, 2002
    On a hill overlooking a lake in Idaho
    Picture # 2 drops between the plugs. The dip stick comes up between the valve cover and the manifold. The header without plugs are only found on 3/4 and above pickups in Calif., 70 to 80 vintage. There are heatshields for the plugs also. The car, usually camaro have the air ports. Junk yard view is your friend.
  10. In2cruisers
    In2cruisers
    5,353
    26
    Aug 13, 2004
    went with the mini truck PS because I think the Sag setup looks scab'ed and wanted more of an OEM look and some of the steering shaft linkage setups I've seen down right scare me
  11. Chula Vista 71 FJ40
    Chula Vista 71 FJ40
    159
    Nov 9, 2008
    Chula Vista, Ca
    Hope you're not talking about my Sag. setup ;p
  12. Texican
    Texican s-Moderator
    5,766
    Media:
    175
    78
    Dec 17, 2002
    Bonham Tx.
    You've looked at the wrong stuff.
    [​IMG]
    http://forum.ih8mud.com/40-55-series-tech/310112-ultimate-front-axle.html
    http://forum.ih8mud.com/tx-lone-star-land-cruisers/314188-jebbers-fj40.html
    You would think you would have figured this out before now, move the engine over one hole in the wings......
  13. pbgbottle
    pbgbottle Forum Lifer
    4,533
    Media:
    92
    220
    Feb 8, 2004
    Cloverdale B.C. Canada
    you could always try one of these style ramhorns if you want to use a ramhorn ,i used this one to clear my stock steering box on one of my older rigs and give me the extra room needed ,the mounting flange is tucked tighter to the block . gonna need a custom y pipe or dual exhaust still tho
    pics
  14. Texican
    Texican s-Moderator
    5,766
    Media:
    175
    78
    Dec 17, 2002
    Bonham Tx.
    The one that is curved to the rear is still the same distance at the area where he is so close to the steering box, I would be more concerned about the heat rather than getting a pipe hooked to it
  15. 2fpower
    2fpower
    5,712
    872
    Sep 5, 2007
    lenexa, ks
    Those are the prettiest pink knuckles!! Must be the wifes FJ...
  16. POTATO LAUNCHER
    POTATO LAUNCHER
    352
    94
    Nov 30, 2009
    Amarillo Tx.
    The heat from my fenderwell header cooked the input seal on the Mini P/S I had previously run. Replaced with Saginaw and forgot about it. :wrench:
  17. In2cruisers
    In2cruisers
    5,353
    26
    Aug 13, 2004
    Oh come on now...Ive done that twice so far....
    even squared up the tranny to match....but Mr. Downey warning me about possible shaft and driveline tunnels being out of wack. Body not available to check for conflicts
    One (of many) reasons the stock engine sits 1" to the drivers side (on USA left hand drive vehicles) is to get the drive shafts into better alignment between transfer-case and differentials (still not a straight shot). Another reason is obviously to keep the transfer-case off the right hand frame rail. My guess is that if you've moved the engine 1" towards the passengers side, you haven't set the body onto the frame yet. You should discover that the transfer-case is darn near into the gas tank, and definitely already digging into the floor sheet metal (i.e. rear of tranny tunnel is too tight to the transfer-case and won't allow it to move to the right very far.
    __________________
    Downey's gone,
    Jim isn't!!!
  18. Texican
    Texican s-Moderator
    5,766
    Media:
    175
    78
    Dec 17, 2002
    Bonham Tx.
    Well....your options
    cook the PS box,
    change the steering setup,
    move the motor
    make your selection now....
    I know of no manifold or header that will solve this.....the low exit ones will actually be closer to the box than the Rams
  19. burnttoastburgos
    burnttoastburgos
    805
    53
    Aug 14, 2005
    Montrose, Colorado
    or run a Scout set-up....clean and still has the oem look.
  20. dgangle
    4,000
    4
    Nov 24, 2004
    Heart of Dixie
    Burnedtoast,
    Please elaborate how you mounted your radiator. Looks nice
