Looks like I've changed my mind......TH350 is the way im leaning now. The chevy 350 I bought was from an automatic so I dont have the bellhousing/flywheel/clutch/fork ect. I was given a TH350 that I can use as a core,and I like the convienience of the automatic transmission for daily driving, the gear ratio is almost the same as the L/C 3spd and then there is the added benifit of the torque conv. multipling the crawl ratio ?....although the lack of engine braking for downhill is a problem. I was thinking that a lockup converter would be the way to go to compensate for that. The A/A kit provides the propper tail shaft and the motor is going to be moving forward anyway. I was told to figure on some drive shaft work with either the 3spd or the auto..so thats the same. The cost of adaptors is within about 150-200 bucks when the additional parts I would need for the manual trans. So what do you guys think...im I making a mistake ? seems like the same set up as the stock 3 spd (gear wise) The only other auto trans would be the 700R..but nobody has given me one of those latley.
