Saginaw pressure
Discussion in '40- & 55-Series Tech' started by kstatecruiser, Mar 10, 2003.
  1. kstatecruiser
    kstatecruiser
    94
    Oct 25, 2002
    Colton, CA
    I was curious if I could use a Saginaw ps pump for a hydro steering setup. &nbsp:Does it produce enough pressure and does it have enough volume for a full hydro setup?
    Thanks
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    http://www.westtexasoffroad.com
    Has enough for assist, will have enough for full as well, just make sure you run a big cooler and big reservoir for the fluid. I'd also run at least semi-synth. Matt did some pump tweaks that work well.
  3. kstatecruiser
    kstatecruiser
    94
    Oct 25, 2002
    Colton, CA
    Thanks. I talked to Matt @ West Texas and he pointed out a few good things. Although I think I am going to try to run a power steering pump from a semi (bigger reservoir, more flow). Now where can I put an extra pulley to run it, or should I just get a bigger belt and run everything on that one belt?
  4. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    IIRC, later FJ40's and FJ55's had a double crank pully....be worth a post in the wanteds....
