Safety /Emissions Test in Utah
Discussion in '40- & 55-Series Tech' started by mhall10407, May 1, 2007.
  1. mhall10407
    mhall10407
    143
    3
    Dec 19, 2004
    Utah
    I'm in the process of moving to Utah and was wondering if someone could tell me what the emissions test in Utah encompasses. I have a 1973 FJ40 registered in a state that does not have safety/emissions and therefore it does not have any smog control. Will this cause a problem registering it in Utah? Do they just hook up a tester to the tailpipe or do they also look for smog/pollution control items that should be included on a 73 model. To make things more complicated the 40 has a 1978 2F engine in it. Any advice would be appreciated.
    Thanks,
    Mike
  2. projektdotnet
    projektdotnet
    1,840
    Sep 26, 2005
    Port Orchard, WA
    removed the air-rail on my 74 and it still passed here.
  3. labsrubric
    labsrubric
    56
    Apr 9, 2007
    Northern California
    Safety test
    Your cruiser is pre smog but the safety part you will have to pass. They basically check that all your lights work (turn signals and brakes)and they check your wipers as well as your horn. I had to install a working horn in my forty once, as well as repair a rust hole in my muffler in order to pass. I used to take my 66 forty to the "se habla espanol" places on State street because they didn't seem to be as picky as everyone else. Plus it was sorta funny watching the looks I would get as they attempted to negotiate my no power steering cruiser with 33s into their little stalls and then administer some crazy brake test where they drive about five miles an hour straight into the stall and jam on the brakes. With a 350 to cruiser 4 speed and no power steering with drum brakes it turned out to be a good time for all onlookers. A Kodak moment for sure. No big cracks in your windshield either. I think that's about it. Good luck.
  4. cruiserboswells
    cruiserboswells
    41
    May 22, 2004
    Wasatch County, Utah
    it depends on your county, Utah County and Salt Lake County have pretty strict emissions but other counties dont have any emissions requirements just a visual inspection. What city are you moving too?
  5. labsrubric
    labsrubric
    56
    Apr 9, 2007
    Northern California
    75 and under
    have no emissions test in Utah. Do they? I always thought it was 75 and under everywhere in Utah?
  6. Benson
    Benson
    204
    1
    Sep 15, 2005
    Utah
    I believe 68 and older have no emmissions test anywhere, but 69 or newer do in Salt Lake, Davis, and Utah counties, which is where most people live.
    Wasatch county = no emmissions. Goodbye smog pump soon!
  7. projektdotnet
    projektdotnet
    1,840
    Sep 26, 2005
    Port Orchard, WA
    Cali is 75 and older utah is 68 and older for the no emissions. As stated most places don't know what they're looking for when they are in a 40 so if it passes the major exterior safety (lights, horns, brakes, etc) major interior (belts, etc) and the sniffer (depending on city) you're golden
  8. labsrubric
    labsrubric
    56
    Apr 9, 2007
    Northern California
    I stand corrected.
    :frown: Tragic. :doh:
  9. fj55-100
    fj55-100 SILVER Star
    421
    37
    Jun 16, 2003
    Just moved to Utah my self and went and got my state inspectors lic , the book is on my tool box .
    The part im in St George does not have emmissions just safety .
    if you need info just ask .
    fj55-100
  10. rdublt1
    rdublt1
    154
    Sep 16, 2004
    SLC, Utah
    I have owned my 73 FJ40 since 1993. It has a built v8 with no smog equipment. It has passed every smog test- way below the maximum allowed. Just make sure it is tuned up and running the good. Basically if you fall within the "sniffer" specs you will be just fine.
    I know in SL county everything 1967 and older does not require emmissions testing. 68 & newer does.
    Like the others have asked, what part of Utah are you moving to?
  11. cruiserboswells
    cruiserboswells
    41
    May 22, 2004
    Benson are you moving to Wasatch county? We have a couple of cruisers here in Heber let me know if you want to go for a run sometime..
