...instead of nerf bars.
So why not build some you ask? OK. I have that old piece of channel that was too heavy to bend for a bumper, so why not?
Many pictures, none of quality.
112" scrap shelving channel.
Marked mid point.
60 grit flapper is great for taking off paint.
If I turn the plasma up high enough to cut this, I pop the breaker...back to the grinder...
This has to go...
That's better.
Capped the cut ends.
Starting to be something.
Measured out and marked locations for square tubing.
Maybe the plasma cutter can do this...if I work it just right and put a new tip on it.
This stuff is pretty heavy.
Tacked on some tube.
So, I still have a little ways to go, but I think it will turn out alright and be pretty strong with gusseting. I am going to size up one side with just two pieces of tube to make sure everything looks right. The front tube on each side will need to be longer to match the shape of the frame. Once I match it all up, I can make measurements and finish it all up. Problem is that it gets dark before I get home from work, so I really don't have good light to do anything outside and I don't have room to bring the truck in and work around it.
Total cost on completion will be around $50, including consumables.
Marked mid point.
This has to go...
That's better.
