I'm having an issue with my engine shutting off when I hit a sudden incline. Possible fuel level issue in the bowl? Once the rig shuts off it has a hard time starting. I depress the gas pedal to floor and hold (hot start procedure). Once it catches, it stumbles and won't hold idle. Black smoke out of the tailpipe. Can't smell anything because I'm smell blind, so nothing to report there. Once that evens out it will hold idle. No issues driving on the street at all, but I probably should get this fixed before I go wheeling... Haha
How is the rig Kline? You doing ok brother.
J
It's doing good. I haven't messed with the carb yet. It keeps running. So, yeah.
I cleaned my SOR diamond plate rubber cargo mat a few days ago and then yesterday a buddy with a 100 Series wanted to get rid of his cargo organizer. So I went to his house and got it installed. It was a little too wide. Narrowed it and it fit between the wheel wells. The depth from seat back to tailgate was good.
I need to figure out what to do with my sub, obviously.
I'm also gonna narrow that top platform so that black box can fit better. And then I can store the ammo can underneath where my lug wrench is.
I've also played with my OEM fan clutch. Pretty sure I put too much fluid in it. And the Torqflo unit I pulled out, which I thought was bad must be good. I'm gonna swap them and then remove fluid from the OEM after it sits for a few days.
Changed my oil tonight
