No, the vent line ends where the axle harness plugs into the sub harness at the left quarter panel. There should be a small rubber cap on the end of the vent tube. The cap has small slit in it to keep dirt and **** out. It would not hurt to extend the vent line to higher grounds.thanks that's what it looks like,does it just fit into the body grommet and vent to the cabin? Does it hook to something?
On the LX you need the complete axle harness which has the wiring for the locker and ABS (which looks like the one you have in your pic.). You will need to add the locker wiring to the sub harness in the left rear quarter (Only the ABS plug is present non-locked LX's). In your picture the smaller rectangular pigtail with the 6 wires is what you will need to add/extend to connect to the main floor 20 pin plug. The main floor plug is inside the left rear quarter behind the jack and runs forward over the wheel arch. You will need 5 female pins to insert into the sub harness side of the 20 pin plug. The 6th wire on your pigtail with the white and black strip is a ground wire and can be ground to the body or jumped to a ground wire on the main floor harness.In the above picture I show a 5 wire plug,is this the one that should be Prewired inLX models? If so then both plugs in the picture should have mates waiting for them Correct? Any LX experts?
For the proper pin-out into the 20 pin plug see post #25 here:
https://forum.ih8mud.com/80-series-tech/381992-lx450-rear-locker-wiring-2.html
and post #21
https://forum.ih8mud.com/80-series-tech/113251-retro-fitting-oem-lockers-wiring-harness-2.html
Hope this helps
